Author Topic: So what have you done to your car today?  (Read 1703607 times)
0 Members and 10 Guests are viewing this topic.
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 AWD,Astra SE
« Reply #1470 on: 21 December 2011, 17:40:27 »
reset eml again (code 0420) !! changed fuel to Total the other day (always fill up at Sainsbury usually) so assuming fuel switch is problem. I do not want to get involved in the sensor repositioning
If I fill at the Sainsbury on Bagshot Road or the one by work in Chertsey I can almost guarantee the light will be on after half a tank to a tank. If I fill at the Shell further along (by the KFC) the light stays off, and has been off for a couple of months now..
That damned eml is back on - I have only one excuse left now and so will refuel at Sainsbury and see what happens just in case I got a dodgy tank of Total a couple of weeks ago.
hotel21
  • The Kingdom of Fife
« Reply #1471 on: 21 December 2011, 17:55:21 »
Try Shell or similar premium fuel rather than supermarket/low volume types.....  ;)
« Reply #1472 on: 21 December 2011, 17:57:11 »
Regassed the aircon for the umtempth time this year ;D
I own a Zafira, I'm allowed to feel depressed.
pscocoa
« Reply #1473 on: 21 December 2011, 18:06:29 »
Had this with my daughter's Focus - the condensor had failed at the rivets as exposed by the green gunge they put in
« Reply #1474 on: 21 December 2011, 18:10:21 »
I know where the leaks are in my case ::)
pscocoa
« Reply #1475 on: 21 December 2011, 18:13:29 »
I take it you are as stubborn in dealing with the aircon problem as I am with fixing the EML :-X
« Reply #1476 on: 21 December 2011, 18:28:23 »
My leak might be some idiot stood with a screwdriver in the valve ::). If it were legal to do that, of course ::)
« Reply #1477 on: 21 December 2011, 18:29:08 »
So quite the opposite, my determination to fix it is the cause of the constant regassing :P
pirate
  • westhumble surrey
    • steinmetz elit estate
« Reply #1478 on: 21 December 2011, 18:38:02 »
finaly got time and fitted rear ibach springs and billies sooo much better dropped her 30 mm dont dip when i boot her and nice and flat on corners fronts are so clapped out she sits level ha ,going to sort them out over hols as still waiting for front billies going to replace top mounts aswell then reset geo, nice .having some wrap done in the new year by company called bossdog in dorking in surrey so watch this space , biggest cost is flowing the crap exhaust system as the cats are realy crap and sport cats are bloody expensive might not bother for the gains ill get ,but would like it to bellow abit when i open her up .
« Reply #1479 on: 22 December 2011, 00:23:03 »
Air con finally regassed after the 'Lorry Incident'. Can now look through the screen without a radar :-X Have also fitted a lead to the ECU for the MID 8) Job for tonight is to connect it ::)
« Reply #1480 on: 22 December 2011, 14:15:30 »
ECU now connected and talking to MID 8)
Got two new front tyres as old ones were starting to tramline badly due to wear on the outer edges, one had lost about a third of its tread >:( :o, the other only the outer inch or so. Got home a tweaked the camber, 2mm one side and 0.5 ish mm on 'tother. Wheels back on and a quick blat down the road and all well. Wheel straighter than it was, no more wandering under braking and no tramlining. Will playtest in controlled conditions at work tonight, but confident that all good :y
Ian_D
  • York
« Reply #1481 on: 22 December 2011, 21:23:52 »
Fixed it  ;D  :y  :)  :D
Finished the Head Gasket + New Cam belt.
[size=12]
Figureman52
  • Nottingham
    • 2.6 CD Saloon
« Reply #1482 on: 22 December 2011, 21:45:39 »
Replaced Thermostat. Hope there are no leaks :y
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #1483 on: 22 December 2011, 22:53:01 »
4 tyres part worns only done 80 miles and the bloke was getting rid of them too noisy for him but sounded ok to me bargin at £120 fitted :), but not so cause found out got a cracked rim which has been giving me a slow puncture :-\
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #1484 on: 22 December 2011, 22:54:36 »
fitted new brakes on rear and found the window breakage wire was loose setting alarm off, silence is soooo golden
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Page created in 0.127 seconds with 21 queries.
