Author Topic: So what have you done to your car today?  (Read 3042992 times)
0 Members and 38 Guests are viewing this topic.
« Reply #19275 on: 21 October 2019, 19:14:18 »
Oooooo matron  ;D
.. and  with no Marina, we know what the remedy will be. :-X
  • Online Online
« Reply #19276 on: 21 October 2019, 19:24:21 »
Oooooo matron  ;D
Tiger balm...
Raeturbo
  • South Wales
    • Mv6 3.2 Mitsi Evo2. XJ8
« Reply #19277 on: 21 October 2019, 20:17:16 »
Or palm oil?
Laying a rubber road.
    • 2 Fords
« Reply #19278 on: 21 October 2019, 23:42:04 »
Oooooo matron  ;D
You're just jealous Ital-boy!  :P  ;D
    • 2 Fords
« Reply #19279 on: 22 October 2019, 15:59:32 »
Picked up my wheel from the tyre shop.  It turns out it was a puncture and they relieved me of £24 to fix it!  :o
Last time I had a puncture fixed, I paid a tenner...   Went home slightly disgruntled and fitted it back on the Mundano  ::)
« Reply #19280 on: 22 October 2019, 17:46:14 »
Picked up my wheel from the tyre shop.  It turns out it was a puncture and they relieved me of £24 to fix it:o
Rip off. :)
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #19281 on: 22 October 2019, 18:16:42 »
Yes, does seem a bit steep.
Changed my 3 year old (15K) track rods for a pair of genuine GM rods from a dealer, after advisory on last MOT test.
Paid £30 to have them aligned and that took less time than your puncture I bet, although I didn't drive home disgruntled.
Omega 2.5 V6 Facelift Estates, a CD & a CDX both in the rare star silver colour.
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite. Boxster. C1.
« Reply #19282 on: 27 October 2019, 16:46:35 »
Having finished the recent anti rust work and refitted the sill covers I rubbed down and primered the minor damage to the rear bumper, caused by me reversing into a bollard about 6 months ago. Then gave it a good wash and dry as it was filthy. Got carried away and gave Airfix 1 a wash too.
Now about to sit down to roast beef with yorkies, roast spuds etc. home made trifle, then make a dent in my 100 bottle stockpile of Hop House 13.
This is to celebrate the last day of my 50,s. From tomorrow I will identify as a 24 year old.
Women are like an AR35. lovely things, but nobody really understands how they work.
« Reply #19283 on: 27 October 2019, 17:34:29 »
I spent yesterday and today stripping down her Mini to replace the timing chain, guides and stem seals.. I'm not finished yet, because I hit some snags. Yesterday was mostly just time - I've never stripped one down this far and spent a good couple of hours trying to liberate the main boost pipe from the rubber hoses (poor access and age & heat having welded them together). Today I had to run to Halfords to pick up a mirror on a stick (can't find mine!) to get the silly flywheel locking pin in (having knocked 10-thou off it in the lathe so that it was actually the right size..)
And now, because the chain wouldn't come out past the VANOS pulley on the exhaust, I had to take the pulley off .. the bolts are one-time-use (stretch bolts - 20Nm and 180deg) so I need a replacement from MINI. So I guess Lou will be driving the Range Rover to work tomorrow!
The chain was a half mm from coming off, casting flash in the way .. I bet 50% of cars it'll sneak past, 50% it won't..
« Reply #19284 on: 27 October 2019, 17:43:40 »
Use mine yesterday for the first time in a bit, and in true Jag style when the battery is less than perfect, the dash was like a Christmas tree.
So took it for a 30 mile spin to get some electricity in it. And all warnings now disappeared. Bloody Indians ;D
It is the original battery, so getting towards tired, plus for some reason that I cant explain, I set the alarm last time I parked it up, which probably adds a tiny bit to the drain.
  • Solihull
    • 530D M Sport, Elite 3.2
« Reply #19285 on: 27 October 2019, 18:47:19 »
Washed the project and had attempt two at cleaning and freeing off the EGR on the Astra... should it fail again I 'should' have a brand new, genuine BNIB one arriving next week for £60 thanks to no one else bidding on it (RRP is £265.00 from VX), also cleaned the MAP sensor..... Bloody filthy diesels  >:(
Rangie
  • Lincolnshire
    • RRS TDV8 Subaru Forester
« Reply #19286 on: 27 October 2019, 19:56:56 »
Used the Range Rover to take the caravan to storage found a new place closer to home and £82 a year cheaper 😀
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #19287 on: 27 October 2019, 21:28:39 »
Do you store the caravan all winter? I'd have thought this was the perfect time of year to get away for better weather!
Raeturbo
  • South Wales
« Reply #19288 on: 27 October 2019, 21:45:16 »
.                        They are pretty tricky to set up the vanos on them
« Reply #19289 on: 27 October 2019, 22:40:00 »
If it's the 150 1.9 I have a clean spare you can have, plus probably some gaskets
Page created in 0.033 seconds with 21 queries.
