Author Topic: So what have you done to your car today?  (Read 4721507 times)
0 Members and 6 Guests are viewing this topic.
« Reply #3645 on: 28 October 2012, 21:46:23 »
These, mostly 8)
Only got to swap the lower pockets from tother door cards and job is jobbed :y
They look REALLY smart Al :y
Details on exactly what you've used would be great!  :-*
« Reply #3646 on: 28 October 2012, 22:45:58 »
For the armrest and cubby hole:
1. Scraper.
2. 200 wet and dry.
3. 400 wet and dry.
4. 800 wet and dry.
5. 1200 wet and dry.
6. 1500 wet and dry.
About 4 coats of Tamiya Colour for Plastics TS29 Semi Gloss Black. Runs, if any, flatted with 800 wet and dry, sanding between coats 1500 wet and dry.
For the trim panel:
Alcantara, stuck on with Evostick general purpose fabric adhesive.
The plastic pins/rivets are carefully ground back with a Dremel, and refitted using Pozi Panhead Stainless Self tappers, 8x1/2, with M5 washers. Double up the washers on the trim strip otherwise the screw tips push through.
I use the Tamiya paints rather than Helfrods as they cover better and are alot more consistant.
« Reply #3647 on: 29 October 2012, 11:11:59 »
Excellent, concise write-up Al thanks very much! :y
    • 530D M Sport, Elite 3.2
« Reply #3648 on: 31 October 2012, 17:00:11 »
Sanded and polished the headlights on the DTi, hopefully with some better quality bulbs fitted as well the road won't look quite so yellow!
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #3649 on: 31 October 2012, 17:11:27 »
just been to reditch to get my car on the lpg register as insurance throwing a tis was over it and refusing cover this yr, place close to me wanted 100 quid so took to the garage who installed in 2005 and was charged 20 quid, brucie bonus well worth the effort, even gave it a full tank of gas on way home
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
« Reply #3650 on: 31 October 2012, 17:37:39 »
Sanded and polished the headlights on the DTi Estate, hopefully with some better quality bulbs fitted as well the road won't look quite so yellow!
EDIT: to Clarify, the estate, Mrs VXL V6's car
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #3651 on: 01 November 2012, 00:40:35 »
well,  me,   not a great deal....
James on the other hand.....    Camcover gaskets, , clean breathers,   oil flush and new oil change , convert from paper to canister oil filter, and change coolant.
nice lad isn't he :D
phill osey
  • holyhead gwynedd wales
    • 2.2 V6 Omega CD Auto
« Reply #3652 on: 01 November 2012, 12:03:52 »
Lee here
Got a bomb ready to blow my omega away
I am so fed up with one damed problem after another
love my Omega
2boxerdogs
« Reply #3653 on: 01 November 2012, 12:20:10 »
Just driven it !! Had not used it for about 10 days due to having some leave ,had to nip over to Cambridgeshire this morning.  Had some idiotic white van man trying to hitch a ride on my rear bumper then he tried to overtake into the path of some hgv's, eventually I had to to do the best thing, floored it and escaped the lunatic made me realise why I love the V6 !!
tgm147
  • Wirral
    • '02 2.2 Omega CD
« Reply #3654 on: 01 November 2012, 12:32:01 »
Put it up for sale. :(
martin42
« Reply #3655 on: 01 November 2012, 17:33:13 »
been doing some work on the cabby past few evenings,now had full service,and both wishbones changed,now drives and runs as she should,and YES i used pattern parts lol  ;D
carpediem82
  • Pajala, Sweden
  • Hej! Opel Omega '95 2.5 V6
    • Omega 2.5 '95
« Reply #3656 on: 04 November 2012, 18:15:53 »
What i did last 2 weeks:
1. New spark plugs
2. changed oil
3.  parking and normal brakes
4.  rear break disks
5. rear shock absorber
6. final and middle right exhaust
7. fitted a thermostat inside the car for the coupe warming
8. fixed extra lights
9. mounted the battery charger inside of car
10. empty it water for windscreen
11. coupled rear seat warming
Later i will post images of what represented final exhaust and the middle.
The last picture was taken today while i was driving, so... who likes snow, is welcome.
With respect,
Francisc
« Reply #3657 on: 04 November 2012, 18:54:40 »
watched the snow fall on it. Sadly, thawed as quick as it fell
« Reply #3658 on: 04 November 2012, 19:53:51 »
Had great plans for today - mainly change the stat,but it rained all day,very hard at times so only managed to take the breaker down off the ramps and remove all four rear light units. :(
Cavalier was so full of shite that I took a new approach to tidying it yesterday. I drove to the council tip and emptied the contents of the car into one of their skips. ;D
twiglet
  • Norwich, Norfolk
« Reply #3659 on: 04 November 2012, 22:59:46 »
Just got back from a 500 mile round trip, starting Friday morning.  Took SWMBO away to a spa hotel for a couple of days rest and relaxation.   :y  The car performed brilliantly and didn't miss a beat!  And for the first time ever, I managed 400 miles on a single tank of fuel!!  8)
Unfortunately, due to the combination of B-roads and horrendous weather, it looks like it's just competed in the RAC Rally...  :-[  Time to break out the pressure washer...  ::)
Page created in 0.381 seconds with 20 queries.
