Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 ... 1852   Go Down
Author Topic: So what have you done to your car today?  (Read 4352924 times)
0 Members and 11 Guests are viewing this topic.
2woody
  • Northumberland
« Reply #75 on: 02 May 2011, 23:27:39 »
have fitted the power-braking system and ABS to my Discovery.
definitely not in the "casual" mods category.
« Reply #76 on: 02 May 2011, 23:48:53 »
Looked at the streak of bird cr@p on the windscreen and made a mental note to wash it, as it was obscuring my view. Then forgot all about it and spent the rest of the day fettling the MX5 hood catches and fixing an oscilloscope. ::)
2woody
  • Northumberland
« Reply #77 on: 03 May 2011, 00:01:51 »
now there is a dark art !
« Reply #78 on: 03 May 2011, 00:03:25 »
The hood catches or the Oscilloscope? I'll tell you what- guess which of the two was a total success... ::)
2woody
  • Northumberland
« Reply #79 on: 03 May 2011, 00:08:20 »
has yours got a hard top, too ?
« Reply #80 on: 03 May 2011, 00:12:10 »
Yes. Well, sort of. It did get robbed for parts until I realised what was going on. ::)
2woody
  • Northumberland
« Reply #81 on: 03 May 2011, 00:19:27 »
reason I asked was 'cos with a hard-top, there's another four catches to wrestle with. I suspect also unsuccessfully.
I'm back to work tomorrow, will find out if the immediate future is middle east, North east, southern UK or redundancy. Will try to send you an e-mail when I know. Have managed to get Rover engine partly built now. Also have bellhousing sorted.
« Last Edit: 03 May 2011, 00:19:58 by 1417_stuart_grange »
« Reply #82 on: 03 May 2011, 00:23:39 »
OK. Hope it turns out to be the right option. :y
Regarding the catches, I think a set of these is what I need:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160582080049
Oh, and a file. ;)
Martian
« Reply #83 on: 03 May 2011, 07:36:58 »
Fixing the scope probably  ;D
Today I shall be crawling around on the floor changing the clutch slave cylinder, and if I'm still up on the roids after that then I might have a look at where the oil is coming from that is smothering the turbo.
ljxcz
« Reply #84 on: 03 May 2011, 08:28:03 »
well
« Reply #85 on: 03 May 2011, 09:19:20 »
Bingo! Although that gave me the run-around for a while. ;D
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #86 on: 03 May 2011, 14:34:43 »
bought all the parts needed for a service pollen filter, oil filter, air filter plugs and oil, oil from opel they wanted €100 for five litres i got some mobil2000 from a local for €20? hope it's alright stuff! on special from €40
Warning: Dates in Calendar are closer than they appear.
neilr
  • Barnet, Herts
« Reply #87 on: 03 May 2011, 16:12:00 »
Friday changed cam cover gaskets &plugs Sat Morn changed 246 coil pack. Sun morn changed fiat coupe pads and disc what a nightmare!! pads were stuck in caliper must have been hammered in. Looked at fiesta mk6 to check for suspension knock found both front springs snapped . Oh for next weekend.
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #88 on: 03 May 2011, 20:40:00 »
Discovered that the centre console makes quite a good improvised can crusher.
Oh, and drank half a can of coke.
TC and BnQ Trade holder.
« Reply #89 on: 03 May 2011, 20:41:26 »
Nothing today, but I have fully tested the Traction Control works perfectly in corners in TheDaddy's MV6 (formally Amigo's Beastie) ::)
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 ... 1852   Go Up
