Pages: 1 ... 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 ... 1497   Go Down
Author Topic: So what have you done to your car today?  (Read 1853301 times)
0 Members and 7 Guests are viewing this topic.
henryd
  • Moaning Old Git
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #945 on: 18 September 2011, 22:25:16 »
My omega became a wedding car yesterday,all polished and ribboned up to take the bride to the wedding and on to the reception,sadly it was her last run out with me as the new owner is having it this week once i have removed my number plate,I shall be sad to see it go but it just doesn't get used enough to justify keeping it(220 miles since the beginning of july :-[)
other rides
  Saab 9-5 Aero HOT estate, Audi A3 2.0 fsi, Pug 306 cabriolet
« Reply #946 on: 19 September 2011, 10:24:47 »
Well, yesterday and Saturday, actually.  ::)
Cam belt, cam cover gaskets, water pump, thermostat, etc. were changed 2K miles ago and last weekend it started leaking coolant. >:(
Immediately assumed it would be the thermostat as I used one of the housings with the thinner type flange.
Stripped it all down and pressurised the system to 1 bar with an airline. Water dribbling out slowly around the crank pulley area but also towards the nearside side of the sump. Hmm.
Thermostat, then? Area around the thermostat appeared bone dry, though. Poking around with a bit of rag on the end of a wire under the joint with the transfer pipe revealed absolutely no moisture also.
Eventually spotted what looked like a little leak around the water pump housing while poking around with a mirror but still wasn't convinced that it wasn't running down behind the backplate from further up.
Decided to pull the water pump off and when I did the sealing O ring looked like it had been on there for 10 years. :o Completely flattened and a texture like plastic. Now, this was a pattern pump. Can't remember where it came from as it had been kept as a spare for a couple of years and it was only changed because the coolant was being changed anyway, and the original had 120k on it. >:( I reckon the O ring was a bit sub-standard.
Back together with a new genuine seal, refilled with coolant and on pressurising the system the leak appears to have been fixed. :y
Drove to work today and no sign of any leakage.
So much for changing the water pump with the cam belt to save time if it fails later. ;D
« Reply #947 on: 19 September 2011, 11:00:41 »
Replaced both trackrod ends.
Bled and serviced front brakes, freed stuck caliper
alignment this afternoon
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #948 on: 19 September 2011, 14:46:04 »
oil &filter change , 2 headlight bulbs :)
dieseldonicely
Omega_Dan
« Reply #949 on: 20 September 2011, 19:32:39 »
Nice new vx oil and filter :y
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
« Reply #950 on: 21 September 2011, 18:13:37 »
Ditto, also replaced crank case breather gasket, slight leek :y  Had a good look under car, OK :y
« Last Edit: 21 September 2011, 18:15:20 by DaveA »
Regards
    Dave
bootie
  • Enix, Almeria, Spain
« Reply #951 on: 21 September 2011, 18:29:26 »
Today I have been having a look at the new camper, a T25 Joker Hi top 1.6 TD.
Few small jobs including making sure the awning and the beds all are OK for sleeping in. Tidy up the electrics a bit but not very sure about the dual battery system especially as there are a few loose or unconnected wires hanging out of the box. All have female connectors on but not connected to anything.
Also sorted out all the curtains and have decided that we will have to get the windows tinted. As the van is blue and silver I think a nice silvered window would look good plus it would reflect the sun better than a dark tint. I may do a blue first then the silver, I dunno yet.
Pulled the dash top to pieces to find a nasty squeak and try to eliminate.
Really looking forward to our first trip away.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #952 on: 21 September 2011, 18:31:31 »
ive been investigating rear bumper removal. once done i have to replace one of my fog lights and clean the bugger  ::) then i have a perfect miggy!!  :) :) :) :)
RIP Paul Lovejoy
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #953 on: 21 September 2011, 18:44:04 »
Italian tune-up, then passed its MoT 8-)
CO 0.028%, HC 3ppm, lambda 1.002 - not bad for five times around the earth!
So I gave it its annual clean.  Then it rained  ::)
I feel like a military academy. Bits of me keep passing out.
« Reply #954 on: 21 September 2011, 19:05:46 »
Nothing on the car, exactly.
Just about killed myself getting this onto the engine stand, though:
(I used a crane, obviously .. I'm not that strong!)
« Last Edit: 21 September 2011, 19:06:03 by aaronjb »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #955 on: 21 September 2011, 19:22:19 »
Enough to make some soup?? :D
« Reply #956 on: 21 September 2011, 19:40:40 »
Not much. My 2 ton trolley jack gave up the ghost, so I had to drive to Colchester and buy a new 3 ton jack. ::)
Big_Al
« Reply #957 on: 21 September 2011, 19:51:34 »
You putting on bit of weight Albs ?  ;D ;D ;D ;D ;D
« Reply #958 on: 21 September 2011, 19:55:19 »
Unfortunately Al, yes. ::) ;D
« Reply #959 on: 21 September 2011, 19:56:15 »
That's awful news. Don't they sell jacks anywhere else? ;)
Pages: 1 ... 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 ... 1497   Go Up
Page created in 0.153 seconds with 21 queries.
