Author Topic: No heater after after HBV change  (Read 691 times)
Big_Al
« on: 15 September 2006, 23:26:54 »
Hi Guys, can anybody help on this one . just changed HBV & flushed out cooling system as my 3.0 was running a bit warm  ( around 100 mark) This has cured that problem & gauge now sits steady at 95. But cant get heater to blow hot . Cold & air con are fine. Both pipes at bulkhead to heater matrix in engine bay  are hot but no heat inside car . HELP !   cheers, Big Al
Admin
Re: No heater after after HBV change
« Reply #1 on: 16 September 2006, 00:07:45 »
I recommend checking all your vacuum connections Al. The heater system is vacuum controlled so that is most likely where the problem is. :)
The Administrator.
  • Millennium Man
    • The missus mad
« Reply #2 on: 16 September 2006, 08:53:56 »
You may have a small airlock causing a problem as well.  But vacuums, as suggested, are most likely...
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Big_Al
« Reply #3 on: 18 September 2006, 07:26:15 »
Thanks , I will check out the the vac connections.
Page created in 0.091 seconds with 21 queries.
