Author Topic: Alarm Backup Battery  (Read 2640 times)
    • 3.2 Elite & Zafira Tourer
« on: 18 September 2006, 09:14:28 »
Seached for "Battery" and could not find a thread on the alarm module  :-/
Anywho my backup alarm battery is beeping now!  :(
I remember a link being posted someware, but can't find it now. But someone knew the type of battery it was? - And posted a link of someware to buy them??
Also does the alarm need to be re-enabled with Tech2 after the battery has been changed?
For replacing the battery, my understanding is (correct me if i am wrong)
You take off the scuttle and the alarm backup module is underneath the drivers side scuttle, loosen the wires, then iginiton on /off (do i remove the key?) - Take off the negative wire within 15 seconds of igition going off or the powersounder will go off.
Take the module to bits (its sealed unit so a very large hammer is needed  ;) ;D) - replace the battery, then wire it back up, ignition on / off
Job done?
« Last Edit: 18 September 2006, 09:28:52 by tunnie »
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Alarm Backup Battery
« Reply #1 on: 18 September 2006, 11:06:14 »
Thats how I remember it.
Think this was the site
http://www.cellpacksolutions.co.uk
Think you need two NC-M120
Do they still have any, company that makes them went tits up?
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
« Reply #2 on: 18 September 2006, 11:38:58 »
Cheers Iggy, did a search and it forwarded me to this site:
http://www.batterytastic.co.uk/Search_Data_Sheet.asp?ID=NC-M3.6R10
Bit steep for 2 batterys!! - I guess its cheaper than a whole new module from Vauxhall!
STMO123
« Reply #3 on: 18 September 2006, 19:04:29 »
Do what I did Mark, just disconnect the bl**dy thing! (But, as Marks DTM advised me,dont tell your insurance).
« Reply #4 on: 18 September 2006, 19:47:42 »
I agree as he said don't tell your insurance company
« Reply #5 on: 18 September 2006, 22:53:29 »
I like i like, no cost fix  ;)
Soo just do as above, key in ignition on then off, and remove the negative wire to the module? Or just unplug the loom completeley?
Does the key need to be removed after the ignition off/on, as the MID says on....
STMO123
« Reply #6 on: 19 September 2006, 07:14:18 »
Ignition off. Unscrew one star type screw which holds the scuttle just below drivers side wiper. Lift up gently and you should see a small metal box(the sounder). Reach in and disconnect the electrics. No need to worry about ignition on/off or all that jazz, cause your disconnecting the very thing you would set off ;)
Thats the 2.5, Mark, cant say exactly for yours [smiley=thumbsup.gif]
EDIT: This message will self-destruct in 6 hours. will you be up by then ;D
« Last Edit: 19 September 2006, 07:17:26 by STMO123 »
  • Millennium Man
    • The missus mad
« Reply #7 on: 19 September 2006, 09:44:14 »
Pop it round, I can disconnect.  Wouldn't mine tech2 to check if any steering settings (unlikely), and to see if that intermittent cam sensor code has reoccurred...
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Page created in 0.112 seconds with 21 queries.
