Author Topic: HBV vacuum pipe  (Read 581 times)
Big_Al
HBV vacuum pipe
« on: 19 September 2006, 19:58:18 »
Hi guys , anyone help on this one.  Heater won't get hot  or even warm. I have no vacuum when i take the pipe off of the HBV with the engine running. No vac in any positon from hi down to low. Have blown through this pipe & can hear air passing from some where to the lower right of the glove box. Also done a smoke test & smoke is coming from that area as well. I presume that the other end of this pipe has come off from the vacuum supply. Does anyone know where it should go onto after it passes through the bulkhead & where abouts it is located . I'd like some help prior to trying to dismantle the dash board & electronic air control panel &messing it all up. Thanks guys,  Big Al
  • Millennium Man
    • The missus mad
Re: HBV vacuum pipe
« Reply #1 on: 19 September 2006, 21:32:06 »
Soz, don't know where it goes, but it will be to one of the solenoids there, and the solenoid is driven by ECC unit...
Unless someones knows better, its gonna be a glovebox out job I suspect, but may be worth just taking off the cardboard bit and the footwell distribution pipe to see it that gives enough access...
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Page created in 0.166 seconds with 22 queries.
