Author Topic: "Check Coolant" Sensor gone - new tank?  (Read 4790 times)
-Alex-
  • Near Cardiff
  • Link-road Specialist
« on: 03 June 2008, 14:42:26 »
Hi again all - am I right in thinking that if your sensor has gone (and cleaning doesn't work) it's new expansion-tank time please?
If so, are all petrol Omega expansion tanks the same please? Mine is a 3.0 MV6 2000 if this makes a difference.
Have shorted the sensor out and the error went away, there is plenty of lovely fresh coolant in there, bang on the mark.
Thank you
Alex
« Last Edit: 03 June 2008, 15:00:43 by -Alex- »
MV6 - I farking love it!
  • Online Online
Re: "Check Coolant" Sensor gone - new tank?
« Reply #1 on: 03 June 2008, 15:03:36 »
Yes. ;) Pretty sure they're all the same, just that some don't have the level sensor, just ask at the Vauxhall parts desk.  :y
« Reply #2 on: 03 June 2008, 15:11:39 »
 TANK, RADIATOR HEADER
Usage : 20SE, X20SE, X20XEV, Y22XE, Z22XE, X25XE, Y26SE, X30XE, Y32SE, X20DTH, Y22DTH
part number : 90500223
Kat no : 13 04 203
Quantity : 1
Note: USED WITH MULTI-FUNCTION DISPLAY
HTH  :)
The only different ones are those for no MFD and those for TD's  :)
« Last Edit: 03 June 2008, 15:13:07 by entwood »
-Alex-
  • Near Cardiff
« Reply #3 on: 03 June 2008, 15:52:53 »
Thanks for your answers guys - so quick too!
How much wonga would you reckon on parting with to get a new one please? If it's expensive I'll try my hand at a good second-hand one and clean it up :)
« Reply #4 on: 03 June 2008, 15:58:14 »
Well try a de-scaler in the header tank you have to.
30ish quid rings a bell for a new one
-Alex-
  • Near Cardiff
« Reply #5 on: 03 June 2008, 16:15:31 »
Thanks chaps - will check it out. If £30 is what it is I'll take it ;D
Albert1
  • Herts
« Reply #6 on: 03 June 2008, 16:18:29 »
Lisles of Knebworth (now Marshalls) quoted me £42 three years ago when I first got my Omega; I settled for shorting the circuit and relying upon a regular visual check - the checks need to be done anyway, even with a working sensor.
-Alex-
  • Near Cardiff
« Reply #7 on: 03 June 2008, 16:33:38 »
Quite correct of course always best to check yourself!
-Alex-
  • Near Cardiff
« Reply #8 on: 04 June 2008, 15:53:22 »
Got a new one of these today from VX - as near as makes no difference £35 inc VAT :)
« Reply #9 on: 04 June 2008, 19:57:25 »
Late now, I know, but worth popping the reed switch out and touching up the joints - found a couple of dry ones lately.
-Alex-
  • Near Cardiff
« Reply #10 on: 05 June 2008, 09:41:12 »
Thanks TB - good to know in case it happens with my new tank anyway :)
