Author Topic: Can I reuse head gasket & bolts?  (Read 4035 times)
Martin_1962
« on: 25 May 2009, 19:06:35 »
Fitted yesterday, removed tonight, can I reuse tomorrow or do I need a new one, done about five miles before finding the problem
Re: Can I reuse head gasket & bolts?
« Reply #1 on: 25 May 2009, 19:07:12 »
I would say no as they are designed to stretch when fitted.
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 25 May 2009, 19:16:44 »
i wouldnt have a problem with reuseing them martin  :y
« Reply #3 on: 25 May 2009, 19:17:08 »
1) As crazy as it sounds, it would probably run OK
2) However, for the low cost of a gasket and a few bolts, and given that you want to keep the car for some time - the only thing to do is to replace them.  :y
By the way - was the gasket fitted correctly?
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #4 on: 25 May 2009, 19:18:40 »
if you want to do the job correctly then get new gasket and bolts, its very risky to try and use used ones again. ( its not worth the hassel )
He who brakes Looses
To old to die young
Omega man 2
« Reply #5 on: 25 May 2009, 19:19:38 »
I wouldn't :-/
espen22
  • Norway(the coldest part of it)
« Reply #6 on: 25 May 2009, 19:21:22 »
No to the gasket, thats a bad idea. the bolts are not stretching like they should when they are reused so u are risking a head gasket failure over time, but i have done it on my own cars a couple of times..
Martin_1962
« Reply #7 on: 25 May 2009, 19:30:51 »
Gasket was upside down - I had heat stroke and was working while a bit out of it.
Depends if I can get one tomorrow
« Reply #8 on: 25 May 2009, 19:34:31 »
Oops!
Well - I left a follower out - I'm glad someone else can make a mistake also ;D
Glad you sorted it though mate - at least you can sort it now  :y
« Reply #9 on: 25 May 2009, 19:39:42 »
Gasket was upside down  ......
What are your cam support bearings like? I lnow it's not been driven far, but it seems you've had no oil flow to the heads.  :(
Martin_1962
« Reply #10 on: 25 May 2009, 19:41:10 »
Oops!
4 days off the road though now - it did go well on the test drive even though it was noisy.
It survived because I had smothered it in oil.
For a little drive it was nearly 3.0 performance - until it got too noisy.
Martin_1962
« Reply #11 on: 25 May 2009, 19:43:25 »
7 are fine, 1 has slight surface marks. Looks OK.
Cam is fine.Cams are fine
It will do anyway, if it does go bad I will refit the original head after refurbishing it.
However I cannot remove 135 without doing 246 as well
« Last Edit: 25 May 2009, 19:43:57 by Martin_1962 »
« Reply #12 on: 25 May 2009, 19:45:20 »
Why's that?  :-/
Martin_1962
« Reply #13 on: 25 May 2009, 19:45:54 »
It might not have been far but I tipped a lot of oil over them before fitting the cam cover.
Worst case I just rebuild old 135, so better stock up on gaskets ect
Martin_1962
« Reply #14 on: 25 May 2009, 19:47:13 »
Why's that?  :-/
Can't remove 135 without moving the coolant pipe, can't unbolt that with 246 in the way.
I have short fingers and wide hands.
