Author Topic: heater blows cold on n/s hot on o/s  (Read 1246 times)
turbo
  • lowestoft
« on: 07 November 2009, 18:58:30 »
could anyone please tell me why the nearside fan wont get hot ,its a nightmare as half of my front window steams upwhile the other side is ok ? :(
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: heater blows cold on n/s hot on o/s
« Reply #1 on: 08 November 2009, 05:02:34 »
what dash do you have buttons or knobs, knobs is controld by a valve by a cable, but i think yours is air fault, if one side is working ok then it would prob be the air switch that opens and closes the air piston valves inside the dash, if you have the knob type you should hear a thud if you wiggle the diretshion from window to front vents if you dont hear a thud then one of the air valves is not working, so will need to take off the frunt of the unit and check the air pipes and the air valves. the buttons type are motors, if it is buttons it mabe the fuse or motor has gone.
Welung666
« Reply #2 on: 08 November 2009, 10:11:48 »
As yours is a facelift it'll have climate. Try resetting it by holding the OFF and AUTO together for about 5 seconds or until you hear the servos kick in.
« Reply #3 on: 08 November 2009, 11:00:41 »
Could well be this http://www.omegaowners.com/forum/YaBB.pl?num=1196616207
« Reply #4 on: 08 November 2009, 11:04:31 »
All facelifts have climate  :y
« Reply #5 on: 08 November 2009, 15:12:54 »
Correct  :y
