Author Topic: Oil in plug "tubes"  (Read 2374 times)
57velox
Oil in plug "tubes"
« on: 09 August 2010, 18:37:49 »
When I serviced my 2002 2.2 Omega, I removed the HT bar thing only to discover the tubes down to the sparkplugs were full of oil.
I assumed some clumsy person had spilt the oil when it filling but now after about 1000 miles I removed the HT bar again and yes, full of oil again!
Its running beautifully and not using any oil.
Has anyone else experienced this problem and any ideas where the oil is coming from??
Thanks, Steve.
tidla
  • solihull
Re: Oil in plug "tubes"
« Reply #1 on: 09 August 2010, 18:42:25 »
the good old rocker cover gasket.
« Reply #2 on: 09 August 2010, 18:45:23 »
Seconded... Buy genuine Vauxhall and replace ASAP or you'll develop more problems :y :y
panderson
  • Ayrshire, Scotland
« Reply #3 on: 09 August 2010, 18:46:29 »
Hi 57velox - welcome to the OOF forum with your first post.
It's a known problem with the cam cover gasket, a job I'm just about to do for myself.
I found this maintanence guide on the forum but don't know if it's applicable to your model......
http://www.omegaowners.com/forum/YaBB.pl?num=1225024176
« Reply #4 on: 09 August 2010, 18:47:34 »
Get it sorted quick or you will fubar your coil pack! The oil will ruin the rubber plug sleeves & cause misfiring. :(
« Reply #5 on: 09 August 2010, 18:47:48 »
Oh yes... And welcome to the Forum :y :y
« Reply #6 on: 09 August 2010, 18:58:27 »
:-[ Sorry 57velox  :-[ very ignorant of me, Welcome to the OOF  ;D :y
Thanks for reminding me of my Manners LD  :y
« Reply #7 on: 09 August 2010, 19:00:37 »
Only because I didn't spot it either :-[ :-[
57velox
« Reply #8 on: 09 August 2010, 19:01:58 »
Thanks Everyone!!
I never expected tis much advice so quickly... This is a brilliant website.
« Reply #9 on: 09 August 2010, 19:03:17 »
Thanks Everyone!!
You'll be hard pushed to find a better one :y :y
Shrek
  • Fife , Scotland
« Reply #10 on: 09 August 2010, 19:06:58 »
Welcome to the forum
You must clean out all the breathers at the same time or you will blow the new gasket in no time as well  :y
"My Naff Code Reader" and OBD2 readers available .
tidla
  • solihull
« Reply #11 on: 09 August 2010, 21:35:20 »
do the 2.2 suffer the same?
Shrek
  • Fife , Scotland
« Reply #12 on: 09 August 2010, 21:37:30 »
Yeah ... mine were totally blocked when my plug wells were full of oil ... i cleared all mine before doing the gasket and now over a year later not a drop of oil in the plug wells ... quite an easy job to clear them out though ... mine probly due for another clean out now i think of it  :y
« Last Edit: 09 August 2010, 21:39:25 by Shrek »
GaryBC
  • Egham, Surrey
« Reply #13 on: 09 August 2010, 23:51:55 »
Echoing everyone else's sentiments - welcome!! You'll find loads of really useful help here!!  :y :y :y
As for your rocker box gaskets if, as appears to be the norm, it's your breathers that are blocked, a really gentle right foot while waiting to fix them helps stem the flow of oil enormously. The less you press the loud pedal the lower the crankcase pressure buildup so the less oil is pumped out.
