Author Topic: EGR Valve sourcing and pricing  (Read 1348 times)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« on: 22 September 2010, 10:08:04 »
hi Guys....  Miggy needs a new EGR valve (and gasket) , Garage have quote me £254..   I'm pretty sure i remember paying about half that on Jaime's trade club card last time (on previous miggy) ...
can anyone confirm or deny this....  preferably in a hurry.//    I need the damn car at the weekend , so need to give the garage a go ahead, or an alternative ASAP.
thanks.
Max
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: EGR Valve sourcing and pricing
« Reply #1 on: 22 September 2010, 10:15:38 »
why dont you make a metal gasket & blank it off, or buy second hand. i have one here off a 3.0l. :y
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #2 on: 22 September 2010, 10:16:51 »
you could call up your dealer and ask them for the tradeclub / abs price?
Fuse 19
« Reply #3 on: 22 September 2010, 10:20:41 »
Clean it out with oven cleaner and then refit with a blanking plate.
I seem to recall the Vx item (blanking plate) used on Astras etc fits.
« Reply #4 on: 22 September 2010, 10:22:34 »
Dealers call it a "plug" # 92065430
They also do this one Astra MK4, Signum, Vectra C, Zafira (Z22SE engines) GM Part Number: 24575592
« Last Edit: 22 September 2010, 10:24:18 by RobG »
MaxV6
  • Oxford UK
« Reply #5 on: 22 September 2010, 10:24:15 »
I wondered about the Blanking plate thing....   what's best to use for this asa temporary measure?
and Mark, why clean it out with oven cleaner if blanking and replacing?  (the housing is cracked between the manifold and valve itself....   so it needs a new one... period...     happy to buy a second hand unit, just in a hurry to get the car road worthy, need to go to Louth (lincs) at the weekend.
The Red Baron
« Reply #6 on: 22 September 2010, 10:31:46 »
pm sent max.
« Reply #7 on: 22 September 2010, 10:35:02 »
according to my EPC, that is NLS, and the replacement is 92065430 of which there is no picture, the other part number looks right though  :y
    • R320 TDM850 SmartRoadster
« Reply #8 on: 22 September 2010, 10:37:18 »
.....   so it needs a new one... period...     .....
you mean FULL STOP!!!!  :-X :-X ;) :y
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #9 on: 22 September 2010, 10:53:55 »
Hi
Just blank off the broken one.  It needs to be cleaned out and the pintle moving and then connected electrically or it will put the fault light on.
Alan
MaxV6
  • Oxford UK
« Reply #10 on: 22 September 2010, 22:06:01 »
WTF is a Pintle?
will it be okay if the thing is blocked up using said part no, refitted, and connected....
regards the fault, i'm given to understand it's not the valve itself, but the valve housing, just below the base of the block top bit,  it is cracked, and blowing....   so if blocked, it will stop blowing, and continue to behave until i can get the baron's one fitted.... yes?
The Red Baron
« Reply #11 on: 23 September 2010, 08:05:36 »
WTF is a Pintle?
Fuse 19
« Reply #12 on: 23 September 2010, 11:39:31 »
It wont be cracked (unless somehow the garage have broken it), there will be signs of soot around the base where the seal between the body and base has failed.
Hence, cleaning the pintel so it moves and gives the correct feedback to the ECU and a blanking plate is an ideal long term fix.
MaxV6
  • Oxford UK
« Reply #13 on: 23 September 2010, 11:48:10 »
understood, up tot he point where you said pintel.
WTF IS A PINTEL?
just curious....
« Reply #14 on: 23 September 2010, 11:51:42 »
the little plunger inside  :y
Page created in 0.12 seconds with 21 queries.
