Author Topic: A few questions if anyone can help  (Read 955 times)
henryd
  • Moaning Haddock Head
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: A few questions if anyone can help
« Reply #15 on: 17 May 2011, 12:36:02 »
Because i've had many vx's with tc and can tell when it steps in without a light telling me it is.
If its like the abs system the bulb makes up part of the circuit so no bulb = no worky
other rides
  Saab 9-5 Aero HOT estate,Focus 1.6 mk2,Pug 306 cabriolet
51M0N
  • Hull
« Reply #16 on: 17 May 2011, 13:05:47 »
That was my thought hence the question  ::)
funny though as the ABS does work, but no light  :-/
VR4Dave
  • Lincoln
« Reply #17 on: 17 May 2011, 15:08:33 »
Re number of rocker gaskets:
There are two different types, I assume they swapped at some point from one to the other.
One type has 4 seperate gaskets (total) to do both banks (2 gaskets per bank), and the other type have 2 gaskets (1 per bank)
If you get the replacements that is 1 gasket per bank they will slot straight in however the other type will need a "bridge" of sealant putting in the gasket channel on the cam cover in 2 places to join the 2 together.
This will become apparent when you have the covers off
Chances are that if your replacements look small you only have replacements for one side.
51M0N
  • Hull
« Reply #18 on: 17 May 2011, 15:11:24 »
Just looked into it more its 4 separate ones vaux do them in pairs though for £6 each  :D
Pain in the a**  :(
« Reply #19 on: 17 May 2011, 17:08:27 »
Camcover gaskets are one of the things that Genuine Vx is recommended for... Some people have had pattern ones fail within a year.
Obviously you'll need to clean the breathers through too ;)
henryd
  • west cornwall
« Reply #20 on: 17 May 2011, 19:25:14 »
thats not going to help come mot time :'(
other rides
51M0N
  • Hull
« Reply #21 on: 17 May 2011, 19:54:42 »
Neither will having no cats.
perks of being in the motor trade  ;D
henryd
  • west cornwall
« Reply #22 on: 17 May 2011, 20:01:34 »
I am in the motor trade,shouldn't make any difference unless you are writing the ticket :-/
other rides
51M0N
  • Hull
« Reply #23 on: 17 May 2011, 20:04:01 »
Trivial daft things like that can be overlooked, obviously if there was a serious fault it would fail,
    • R320 TDM850 SmartRoadster
« Reply #24 on: 17 May 2011, 20:24:21 »
To be hoped you don't get into the sales side of things. If ABS is fitted, I would expect it to work.
Bent valve
« Reply #25 on: 17 May 2011, 20:40:41 »
To be hoped you don't get into the sales side of things. If ABS is fitted, I would expect it to work.[/quote]
I disagree. This guy sounds like he would make a good secondhand car salesman ;)
« Reply #26 on: 17 May 2011, 20:41:40 »
I think you are missing the point ....
You say the TC does not work .. by knowledge and feel ...
You say the bulb never illuminates ... ever no matter what switching is made... or on ignition on.
Therefore .. if bulb has been removed (or blown) it cannot illuminate....  if it WAS illuminated it would indicate a fault in the TC that TURNS TC OFF ... which is .. probably .. why it doesn't work.
My money is on the previous owner removing the TC bulb to hide a known fault ....
Moral .. check all bulbs illuminate at ignition switch on when buying a car .. :)
51M0N
  • Hull
« Reply #27 on: 18 May 2011, 08:43:28 »
Well when I get chance i'll be taking them out and we shall see eh  8-)
Page created in 0.162 seconds with 22 queries.
