Author Topic: HELP!!!!!  (Read 1624 times)
51M0N
  • Hull
Re: HELP!!!!!
« Reply #15 on: 09 July 2011, 20:48:44 »
where would that be on my 3.0? is it at the front of the passenger side bank?
Re: HELP!!!!!
« Reply #16 on: 09 July 2011, 20:54:01 »
51M0N
  • Hull
Re: HELP!!!!!
« Reply #17 on: 09 July 2011, 20:54:48 »
checked crank sensor where it plugs in at the rear of the engine. its plugged in, ive not been underneath it so it cant be that, i wonder perhaps the wiring bridge over the passenger side bank if ive knackered a wire?
Re: HELP!!!!!
« Reply #18 on: 09 July 2011, 21:09:27 »
I dont know i dont know how to flash code these.
checked the plug leads they are in the correct order. checked the injectors are plugged in, checked everything!
Now it wont start at all. its turns over then dies.
Not doubting you but are you 100% sure, also are the leads secure in the dis?
51M0N
  • Hull
Re: HELP!!!!!
« Reply #19 on: 09 July 2011, 21:17:19 »
I doubted myself so i switched the 2 around i wasnt 100% on and it made no difference.
Re: HELP!!!!!
« Reply #20 on: 09 July 2011, 21:25:49 »
Like this :question
   Bulkhead
DIS    5   3   1
Plug   2   6   4
   Front of car
« Last Edit: 09 July 2011, 21:27:30 by RobG »
51M0N
  • Hull
Re: HELP!!!!!
« Reply #21 on: 09 July 2011, 21:31:25 »
yep, i never took the leads of the coil, just off the plugs.
checked the coil anyway in case i pulled one off but even if one was off should still start?
51M0N
  • Hull
Re: HELP!!!!!
« Reply #22 on: 10 July 2011, 09:43:42 »
Going to take everything off again and check for any broken wires etc
Re: HELP!!!!!
« Reply #23 on: 10 July 2011, 10:16:59 »
Cam sensor wire trapped under cam cover ?
51M0N
  • Hull
Re: HELP!!!!!
« Reply #24 on: 10 July 2011, 10:25:31 »
no its not, i noticed when i took them off so made sure it didnt. nothing is trapped under the cam covers.
tigers_gonads
  • Moaning Haddock Head
  • Kinston Upon Hull
    • 02 Mv6 Estate (lpg'd)
Re: HELP!!!!!
« Reply #25 on: 10 July 2011, 10:31:22 »
Where abouts in Hull are you ?
Please note, 95% of my posts are piss take or banter and should always be taken as so.
Please feel free to give it back in the same spirit.
51M0N
  • Hull
Re: HELP!!!!!
« Reply #26 on: 10 July 2011, 10:36:08 »
kingswood, want my number?
51M0N
  • Hull
Re: HELP!!!!!
« Reply #27 on: 10 July 2011, 10:37:18 »
i looked at the coil location on this photo http://images.omegaowners.com/images/guides/v6_engine_pics/IMG_0025.jpg mine is the other way round, as in the plug is at the opposite end and its mounted on its side.
tigers_gonads
  • Kinston Upon Hull
Re: HELP!!!!!
« Reply #28 on: 10 July 2011, 10:38:19 »
pm us your mobile number  :y
tigers_gonads
  • Kinston Upon Hull
Re: HELP!!!!!
« Reply #29 on: 10 July 2011, 10:41:47 »
incoming  ;D
Pages: 1 [2] 3 4  All   Go Up
Page created in 0.133 seconds with 22 queries.
