Author Topic: Self Leveling Suspension.  (Read 10203 times)
amba
  • Medway towns
    • German V6
Re: Self Leveling Suspension.
« Reply #30 on: 22 July 2011, 11:53:26 »
Must say the 2nd picture does look more like a s/l pump,especially as its mounting points are clear in my mind at the moment as replaced mine a week or so ago.
Electrical plug also looks very similar so my money is on picture #2 being the pump.
Picture #1 looks more like the secondary air pump also.
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« Reply #31 on: 22 July 2011, 11:53:47 »
Those were only two "things" in the corners  of bumper and wings on both sides. I'll take another look as soon as I get back home. In 30 min, I wish i would what does it look like. ThanksThose were only two "things" in the corners  of bumper and wings on both sides. I'll take another look as soon as I get back home. In 30 min, I wish i would what does it look like. Thanks
danzigfan
« Reply #32 on: 22 July 2011, 11:56:36 »
2nd pic is from under the right side, under the light.
danzigfan
« Reply #33 on: 22 July 2011, 13:24:05 »
Fast one, please.....Fuse for avto leveling is nuber 27 fuse? Because I'm missing it.... Which fuse is it, 10A 20A? I want to try it, please
« Reply #34 on: 22 July 2011, 13:30:17 »
20A
danzigfan
« Reply #35 on: 22 July 2011, 13:32:56 »
And one more thing, the switch by differencial - I hope previous owner has put it back in right position. I don't want an offroad omega :D
danzigfan
« Reply #36 on: 22 July 2011, 13:35:08 »
Thanks, I'll put fuse in and start the car.......(to be continued)
danzigfan
« Reply #37 on: 22 July 2011, 13:48:44 »
Nothing.....what weight should be in the back? Or maybe it's dead
amba
  • Medway towns
    • German V6
« Reply #38 on: 22 July 2011, 14:34:49 »
Can you hear the pump start running after the ignition is switched on ?
Simplest method is to pull off 1 of the thin black air lines from the top of the rear suspension shock absorber,then turn ignition on and you should be greated with a steady flow of air from the end of the pipe.
danzigfan
« Reply #39 on: 22 July 2011, 15:56:04 »
Can't do that now because it's raining again. I didn't hear compressor so I'll try this option
danzigfan
« Reply #40 on: 17 August 2011, 14:45:56 »
so the compressor is out, now just to see if it gets signal at all or the problem is somewhete else. Sugestions are welcome, thanks
danzigfan
« Reply #41 on: 17 August 2011, 14:47:31 »
Eeemmm, is image too big? First time with photobucket sory
danzigfan
« Reply #42 on: 17 August 2011, 15:00:58 »
Got electricity, still nothing. Going to disassemble compressor now and see what's inside
danzigfan
« Reply #43 on: 17 August 2011, 15:10:11 »
danzigfan
« Reply #44 on: 17 August 2011, 16:33:56 »
IT'S ALIVE......ALIVE!!!!!!!! ;D 8-) :y
Pages: 1 2 [3] 4  All   Go Up
