Author Topic: Fitting MID into police spec 2001 MV6 (facelift)  (Read 3788 times)
Fuse 19
Re: Fitting MID into police spec 2001 MV6 (facelif
« Reply #15 on: 26 July 2006, 08:42:47 »
If you have the NCDC2013 to go with it it might be easier as the trip functions are controled via the selector on the audio units front panel and not by the indicator stalk (there is a can bus link between the NCDC and GID/CID).
The bulb check control is not done by the display, its a seperate module but, as mentioned before, its easy to disable.
I will shortly be posting a maintenance guide on how to fit an NCDC to a facelift car with GID or CID plus I will include the neccassary wiring info to.
Page created in 0.106 seconds with 21 queries.
