Author Topic: Rear Lip Spoiler With Brake Light Fitting  (Read 1484 times)
nixoro
  • Hitchin, Herts
« on: 30 August 2006, 17:18:46 »
As in the above I would eventually like to get my hands on one of these but can they be fitted without doing a bodge.
My car at the moment does not have this and was wondering whether it would have a hidden connector in the boot lining for connectivity.
At a guess a hole would need to be made to run the cable in would this be right.
If its too much trouble to fit one with the brake light I shall have a look for one without.
Has anyone added one of these before.
« Last Edit: 30 August 2006, 17:23:37 by nixoro »
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Rear Lip Spoiler With Brake Light Fitting
« Reply #1 on: 30 August 2006, 17:43:01 »
I know who not to ask!!!
Quote from bigrod :-
Unfortunately the spoiler fell off last night, so I reattached it with some bigger wood screws!!
 ;D ;D
Hillper
  • Aylesbury
  • Werthers. Winter, too hard.  Summer, too soft.
« Reply #2 on: 31 August 2006, 10:47:10 »
'No More Nails'!
But seriously, I think they are glued on aren't they?  Mrs Hillper's is.
It's drilling a hole for the wire that would worry me.  Connecting up the wires wouldn't be a problem.
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
nixoro
  • Hitchin, Herts
« Reply #3 on: 31 August 2006, 11:41:38 »
Not so bothered about drilling when I come to do it but does anyone think there maybe a connector in the bootlid.
TheOutcast
« Reply #4 on: 01 September 2006, 07:56:46 »
The spoiler is stuck on, with one small screw at either end, fitted from underneath.
As to the wiring, I have no idea whether there is a conector in the boot lid, it's possible, but if not, just run a wire to one of the existing brake lights.
    • R320 TDM850 SmartRoadster
« Reply #5 on: 01 September 2006, 14:06:38 »
Will that not upset/confuse the brake check system?
Hillper
  • Aylesbury
« Reply #6 on: 01 September 2006, 22:22:50 »
Possibly.  You could do a dummy run with a bulb with wires soldered on, connected across one of the brake light terminals.
I doubt if the system would register a blown bulb if two were in parallel.
But if you used LEDs, it would probably be unaffected.
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #7 on: 02 September 2006, 13:03:35 »
Check system should be unaffected, the high level led brake light on facelifts is connected on the same circuit.
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
Page created in 0.125 seconds with 22 queries.
