Author Topic: A Few Irritating Electrical Problems!  (Read 1229 times)
Corsa_Convertible
« on: 14 September 2006, 16:38:40 »
I have recently become the proud owner of a 1997 Omega Tourer
These may be connected, as they seem to be on the same fuse (14) Which is intact.
Firstly the Heated rear window will not work. I have replaced the switch.... and had the relay checked. interestingly if you manually close the circuit on the relay, the light on the switch comes on and the window de-mists.
Secondly, The Recirculation control seems dead. No light on the switch when toggled, and I can't hear any motors whiring or change in the air flow from outside air to inside air. I've changed the switch, still no joy
Finally the cigarette lighter (front and rear)  does not work although the bulb in it's rim does. Tested both with bulb and wire, dead as a doornail!
Any suggestion (or recommendation of a good auto electrician in the Bristol Area) would be welcome
Thanks you!
Drives a Marmite Car (You'll either love it or hate it!)
Hillper
  • Aylesbury
  • Werthers. Winter, too hard.  Summer, too soft.
Re: A Few Irritating Electrical Problems!
« Reply #1 on: 15 September 2006, 23:41:52 »
I will have a look at my circuit diagram tomorrow.
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #2 on: 21 September 2006, 21:28:51 »
Have you actually tried changing the fuse? I've seen this before, caused by bad spade connections. Get a new fuse and pop it in.
Also get the meter onto both sides of the fuse, make sure your power is ok there.
I'd be very surprised if all these faults were a coincidence.  ::)
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
Hillper
  • Aylesbury
« Reply #3 on: 23 September 2006, 15:46:01 »
Thought I'd replied to this already?
Bit of a coincidence indeed!
Assuming fuses are OK (and we won't know unless he posts again!), the A/C control unit sends the control signal to the relay.  Could be the control unit U/S.
I wonder if the other A/C functions are normal?
Corsa_Convertible
« Reply #4 on: 26 September 2006, 10:04:03 »
Sorry Chaps
On holiday for a week. Meeeega performed admirably, also managed to strip lots on bits and bobs off a scraped Omega for which I was only charged one whole english pound!
Firstly
I have swapped the fuse, I believe fuse 14 has quite a bit on it, including the Radio. Everything works except the above.
Secondly
The A/C (Air Conditioning?) Is okay, quite cold! switch displays little orange light when toggled.
Thanks for your suggestions
CC
Page created in 0.119 seconds with 22 queries.
