Author Topic: Alarm and the use of the indicators  (Read 5255 times)
nixoro
  • Hitchin, Herts
Re: Alarm and the use of the indicators
« Reply #30 on: 18 August 2006, 16:58:56 »
You DON'T have to press the button to enable the sensors. They are on by default, pressing the button before exiting the car and arming the alarm inhibts the ultrasonics.
Thats where I am going wrong [smiley=embarassed.gif] [smiley=lolk.gif]
« Last Edit: 18 August 2006, 16:59:09 by nixoro »
nixoro
  • Hitchin, Herts
« Reply #31 on: 18 August 2006, 17:02:48 »
Also, having the towbar removed shouldn't necessarily effect the alarm function, depending on where the connections were made of course.  :o
You have said the indicators and hazard functions are all ok, so i reckon it's unrelated.
The towbar electrics were connected in behind the plastic trim along the backend of the boot.
« Last Edit: 18 August 2006, 17:03:07 by nixoro »
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #32 on: 18 August 2006, 17:04:19 »
Then the towbar removal is definately unrelated.
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
nixoro
  • Hitchin, Herts
« Reply #33 on: 18 August 2006, 17:07:35 »
Cheers for clearing that one up :) for some reason I thought it maybe related in some way.
Shall see about doing further testing without pressing the red button see if the powersounder goes off.
Kev
  • Glasgow
« Reply #34 on: 18 August 2006, 17:12:42 »
As TheBoy already stated, the PowerSounder will only sound if someone has tried to fiddle with the electrics. i.e. disconnecting the battery.  ;)
nixoro
  • Hitchin, Herts
« Reply #35 on: 18 August 2006, 17:16:26 »
Sorry Kev gotcha, so alarm is working as it should only remember now the power sounder kicked in when reconnecting the battery once caused a right racket.
I wonder why the flashers dont work when locking and unlocking the car, should I worry about it?
Do you think its worth testing the sensors still?
« Last Edit: 18 August 2006, 17:17:05 by nixoro »
  • Millennium Man
    • The missus mad
« Reply #36 on: 18 August 2006, 17:24:29 »
Test the sensors, see what happens.
I reckon the relay or associated connections that controls the indicators in the ATWS is donald ducked - but I will check if there is any config via tech2 over weekend.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
nixoro
  • Hitchin, Herts
« Reply #37 on: 18 August 2006, 17:28:20 »
Cheers TheBoy :)
peter2ltr
  • Liverpool
« Reply #38 on: 15 September 2006, 20:33:56 »
If the alarm has been activated, the indicators will continue to flash even after the alarm has ceased sounding.
                      Peter.
BILL0BLU
  • Isle of Anglesey
« Reply #39 on: 04 October 2006, 14:45:28 »
After reading all the post on this subject has got me wondering.
My indicators dont flash when I lock or unlock my car. (95 2.5 V6) but my car is also fitted with a after market Meta M36T imobiliser. I wonder if this is the reason for my indicators not flashing.
This is how I bought the car so I hadn't given it any thought before.
You lot have got a lot to answer for. LOL ;D ;D ;D
nixoro
  • Hitchin, Herts
« Reply #40 on: 04 October 2006, 15:04:08 »
Right been a while since I last looked at this thread, so I thought I would update a little.
It appears the power sounder goes off when reconnecting the battery, but the internal sensors do jack all.
Am i right to think the horn should go off when the internal sensors are activated.
Tried sitting in the car with windows shut, lock the car the little red light flashes but nought happens if I move about the car. Guessing the sensors are knackered shall swap one from mine to test.
MikeDundee
  • Costa Del Peckham
  • avatar borrowed from DLK for a bit.....
« Reply #41 on: 07 October 2006, 19:26:35 »
 ;Dyeah mine flash, and flash again, old old dear departed last meega did the same also. :'(
  • Millennium Man
    • The missus mad
« Reply #42 on: 07 October 2006, 19:57:18 »
Alarm horn should go off - has it been disconnected?
nixoro
  • Hitchin, Herts
« Reply #43 on: 09 October 2006, 11:48:52 »
Where abouts would this be located, is it connected to the cars main horn or is it seperate?
The power sounder am I right to think is located under the scuttle on the drivers side.
If I can confirm I am going for the right one I shall make sure its connected.
  • Millennium Man
    • The missus mad
« Reply #44 on: 09 October 2006, 18:33:59 »
Different horn to car horn, should be mounted near power sounder, which you've aready found...
Pages: 1 2 [3] 4  All   Go Up
Page created in 0.115 seconds with 22 queries.
