Author Topic: Omega Cabin Fusebox Info  (Read 21525 times)
« on: 23 October 2006, 12:13:27 »
Note: The Omega cabin fuses are located below the steering wheel and are accessed by opening the drop down cover.
94-95 Cars
1--30A Window operation
2--15A Brake lamps, hazard warning flashers
3--30A Windscreen wipers, windscreen washer system
4--10A CD Changer
5--30A Electrically adjustable front seats
6--20A Radio
7--30A Electrically operated windows
8--10A Daylight running lamps (Scandinavia)
9--10A Automatic transmission (for the infirm)
10-
11-10A Heated exterior mirrors
12-20A Courtesy light, tunk lamp, hazard warning flashers, information display, radio
13-10A Electrically adjustable exterior mirrors
14-20A Power steering, cigarette lighter, heated front seats, electrically operated rear window blind
15-15A Reverse lamps, cigarette lighter, glove compartment lamp,automatic transmission, automatic level control system, cruise control, ventilation for rear door windows, position memory for seat and mirror adjustment
16-20A Fog lamps
17-20A Horn
18-20A Fuel pump (useful to remove then run engine to de-pressurise fuel system when changing fuel filter etc!)
19-10A ABS, TC
20-20A Heated rear seats, electrically operated rear window blind, central locking system
21-10A Main beam (left)
22-10A Dipped beam (left) headlamp range adjustment
23-10A Parking and tail lamps
24-20A
25-20A Sunroof
26-10A Number plate lamp, information display, headlamp washer system
27-20A Automatic level control system
28-10A Fog tail lamp
29-20A Terminal 30. constant current for caravan/trailer 30-10A Parking and tail lamps (right)
31-10A Dipped beam (right), headlamp range adjustment
32-10A Main beam (right), control indicators
33-30A Heater fan, air-conditioning system
34-40A Heated rear window
96-97 cars
4--10A CD Changer
6--10A Radio
10-
14-20A Power steering, cigarette lighter, heated front seats, electrically operated rear window blind, air circulation system, electric air conditioning, anti-theft alarm system, heated rear seats
15-15A Reverse lamps, cigarette lighter, glove compartment lamp, automatic transmission, automatic level control system, cruise control, ventilation for rear door windows, seat and mirror adjustment, radio
16-20A Fog lamps
17-20A Horn (not the pot noodle variety)
19-10A ABS, TC
20-20A Heated rear seats, electrically operated rear window blind, central locking, courtesey lamp
24-
25-20A Sunroof
29-20A Terminal 30. constant current for caravan/trailer (pikey optional fit, can be used for simple audio instals)
33-30A Heater fan, air-conditioning system, electric air-conditioning system (climate)
98-2003 cars
4--15A Cooling fan
6--20A Radio
10-30A Heated diesel fuel filter
12-20A Courtesy light, tunk lamp, hazard warning flashers, information display, radio, navigation system
14-30A Power steering, cigarette lighter, heated front seats, electrically operated rear window blind, air circulation system, electric air conditioning, heated rear window
15-20A Reverse lamps, glove compartment lamp, automatic level control system, cruise control, seat and mirror adjustment, radio, heated rear seats, sun roof, instrument illumination, window operation, cooling fan, headlamp range adjustment
16-20A Fog lamps
19-10A ABS, TC
20-20A Courtesy lamp, seat heating, central locking, rear window blind
24-20A Coolant heating
25-20A Sunroof
27-20A Automatic level control system, rear accessory socket
28-20A Fog tail lamp
29-30A Terminal 30. constant current for caravan/trailer (pikey optional fit, can be used for simple audio instals)
31-15A Dipped beam (right), headlamp range adjustment
« Last Edit: 24 July 2007, 14:56:02 by TheBoy »
