Author Topic: V6 Torque Values  (Read 13350 times)
V6 Torque Values
« on: 23 August 2006, 21:32:01 »
DescriptionNmNotes
Adapter, fuel distributor pipe to intake bridge8
Adapter, fuel distributor pipe to fuel distributor pipe15
Starter to cylinder block40
Intake bridge to intake flange20
Intake flange to cylinder head20
Drive disc/flywheel to crankshaft65 + 30° + 15°     1,2
Exhaust manifold to cylinder head203
Oil filter housing cover to oil filter housing25
Heat exchanger cover to heat exchanger30
Heat exchanger cover to cylinder block20
DIS ignition module to member8
Torsional vibration damper to toothed belt drive gear20
Throttle body to intake plenum8
Pressure line to power steering pump28
Accelerator pedal module to bulkhead20
Link rod to stabiliser653
Alternator to cylinder block and oil pump35
Transmission to cylinder block (M8)20
Transmission to cylinder block (M12)60
Transmission holder to underbody454
Threaded sleeves to crankshaft bearing bridge8
Base plate, toothed belt tension roller and toothed belt guide roller to cylinder head40
Auxiliary aggregate(s) support to cylinder block35
Idler bracket to body55 + 75° + 15°1
Rear toothed belt cover to cylinder head and oil pump (M6)8
Rear toothed belt cover to cylinder head and oil pump (M8)10
Crankshaft pulse pick-up in cylinder block8
Crankshaft pulse pick-up disc to crankshaft151
Refrigerant lines to compressor40
Ribbed V-belt pulley to coolant pump8 + 30° + 30° 1 or 12Nm+loctite
Ribbed V-belt pulley to power steering pump20 + 30° + 15°3 or 20Nm+loctite
Ribbed v-belt tension roller to cylinder head35
Knock sensor to cylinder block20
Fuel lines to adapter, fuel distributor pipe15
Fuel distributor pipe to intake bridge8
Coolant bridge to cylinder head305
Coolant intake pipe to exhaust manifold8
Coolant intake pipe to cylinder block20
Coolant pump to cylinder block25
Coolant pipe and engine transport shackle to cylinder head25
Ball joint to steering knuckle1003
Crankshaft bearing bridge to cylinder block20
Crankshaft bearing cap and crankshaft bearing bridge to cylinder block50 + 60° + 15°1
Oxygen sensor in front exhaust pipe306
Steering arm to steering shaft1603
Solenoid valve for intake plenum switchover valve to switchover valve8
Secondary air metal pipe to exhaust manifold20
Engine damping block to engine bracket40
Engine vent housing to cylinder block8
Engine damping block to front axle body55
Engine bracket to cylinder block40
Engine bracket, engine damping block to cylinder block60
Camshaft bearing caps to cylinder head8
Camshaft sprocket to camshaft50 + 60° + 15°1
Camshaft sensor to camshaft bearing cap8
« Last Edit: 25 October 2006, 17:45:55 by Mark »
