Author Topic: Motronic 2.8.1 (V6 Engines) fault codes  (Read 23851 times)
« on: 06 October 2006, 17:33:34 »
10   Variant-Coding Not Programmed
13   O2 Sensor 1 Open Circuit
14   Coolant Temperature Voltage Low
15   Coolant Temperature Voltage High
16   Knock Signal Circuit 1
17   Knock Signal Circuit 2
18   Knock Control Module; Replace Electronic Control Unit (ECU)
19   Incorrect RPM Signal
21   Throttle Position Sensor (TPS) Voltage High
22   Throttle Position Sensor (TPS) Voltage Low
25   Injector Valve 1 Voltage High
26   Injector Valve 2 Voltage High
27   Injector Valve 3 Voltage High
28   Injector Valve 4 Voltage High
29   Injector Valve 5 Voltage High
31   No Engine RPM Signal
32   Injector Valve 6 Voltage High
33   Exhaust Gas Recirculation (EGR) Valve Voltage Low
34   Exhaust Gas Recirculation (EGR) Valve Voltage High
38   O2 Sensor 1 Circuit Voltage Low
39   O2 Sensor 1 Circuit Voltage High
44   O2 Sensor 1 Lean Exhaust
45   O2 Sensor 1 Rich Exhaust
46   Secondary Air Pump Voltage Low
47   Secondary Air Pump Voltage High
48   Battery Voltage Low
49   Battery Voltage High
52   Telltale (Check Light) Voltage High
53   Fuel Pump Relay Voltage Low
54   Fuel Pump Relay Voltage High
55   Replace Electronic Control Unit (ECU)
56   Idle Air Control Voltage High
57   Idle Air Control Voltage Low
59   Intake Manifold Valve 1 Voltage Low
61   Fuel Tank Ventilation Valve Voltage Low
62   Fuel Tank Ventilation Valve Voltage High
63   Intake Manifold Valve 1 Voltage High
69   Intake Air Temperature Voltage Low
71   Intake Air Temperature Voltage High
73   Mass Air Flow Sensor Voltage Low
74   Mass Air Flow Sensor Voltage High
75   Torque Control Voltage Low
76   Continuous Torque Control
81   Injector Valve 1 Voltage Low
82   Injector Valve 2 Voltage Low
83   Injector Valve 3 Voltage Low
84   Injector Valve 4 Voltage Low
85   Injector Valve 5 Voltage Low
86   Injector Valve 6 Voltage Low
87   A/C Cutoff Relay Voltage Low
88   A/C Cutoff Relay Voltage High
89   O2 Sensor 2 Open Circuit
91   O2 Sensor 2 Circuit Voltage High
93   Hall Sensor Voltage Low
94   Hall Sensor Voltage High
98   O2 Sensor 2 Circuit Voltage Low
121   O2 Sensor 2 Lean Exhaust
122   O2 Sensor 2 Rich Exhaust
123   Intake Manifold Valve 1 Blocked
124   Intake Manifold Valve 2 Blocked
127   Camshaft Control Voltage Low
128   Camshaft Control Voltage High
129   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low
131   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High
132   Exhaust Gas Recirculation (EGR) Valve Feedback Incorrect Signal
133   Intake Manifold Valve 2 Voltage Low
134   Intake Manifold Valve 2 Voltage High
135   Telltale (Checklight) Voltage Low
136   Unknown Output Driver Error
137   Electronic Control Unit (ECU) Box Temperature High
141   Secondary Air Pump Not Enough Air
142   Secondary Air Pump Air Without Pump
143   Immobiliser No Or Wrong Signal
144   Immobiliser No Signal
145   Immobiliser Wrong Signal
« Last Edit: 10 December 2007, 09:33:13 by Mark »
