Author Topic: Replacing Door Strap Bush  (Read 14281 times)
« on: 17 October 2006, 18:26:04 »
Nice easy one, only takes a few minutes :)
Tools Required:
2 x 10mm spanners
Parts Required:
Door Bush - PN: 90462823 (19p +VAT retail)
Instructions:
Undo the nut from the bolt that goes through the bush:
Support the door to stop it swinging by itself (Omega doors are heavy!), then withdraw bolt:
Remove old bush and replace with a new one, grease well:
Put bolt back through, may take a bit of wiggling, then do up the nut. Just nip it, it doesn't need to be too tight.
« Last Edit: 24 July 2007, 14:40:21 by TheBoy »
