Author Topic: Simtec 71 (Z22XE 2.2 16V Petrol) codes  (Read 20523 times)
« on: 10 December 2007, 09:06:50 »
P0030   O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1)
P0036   O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2)
P0100   Mass Air Flow Sensor Circuit High Input
P0100   Mass Air Flow Sensor Circuit Low Input
P0110   Intake Air Temperature (IAT) Signal Voltage High
P0110   Intake Air Temperature (IAT) Signal Voltage Low
P0115   Engine-Coolant Temperature Sensor Circuit High Input
P0115   Engine-Coolant Temperature Sensor Circuit Low Input
P0115   Engine Coolant Temperature Sensor Circuit Malfunction
P0120   Throttle Position Sensor (TPS) Circuit 1 Voltage High
P0120   Throttle Position Sensor (TPS) Circuit 1 Voltage Low
P0120   Throttle Position Sensor 1-2 Correlation
P0130   O2 Sensor 1 Circuit Voltage High
P0130   O2 Sensor 1 Circuit Voltage Low
P0130   O2 Sensor 1 Open Circuit
P0130   O2 Sensor 1 Incorrect Signal
P0135   O2 Sensor 1 Heater Voltage High
P0135   O2 Sensor 1 Heater Voltage Low
P0135   O2 Sensor 1 Heater Open Circuit
P0136   O2 Sensor 2 Circuit Voltage High
P0136   O2 Sensor 2 Circuit Voltage Low
P0136   O2 Sensor 2 Open Circuit
P0141   O2 Sensor 2 Heater Voltage High
P0141   O2 Sensor 2 Heater Voltage Low
P0141   O2 Sensor 2 Heater Open Circuit
P0170   Rich Exhaust
P0170   Lean Exhaust
P0201   Injector Valve 1 Voltage High
P0201   Injector Valve 1 Voltage Low
P0201   Injector Valve 1 Open Circuit
P0202   Injector Valve 2 Voltage High
P0202   Injector Valve 2 Voltage Low
P0202   Injector Valve 2 Open Circuit
P0203   Injector Valve 3 Voltage High
P0203   Injector Valve 3 Voltage Low
P0203   Injector Valve 3 Open Circuit
P0204   Injector Valve 4 Voltage High
P0204   Injector Valve 4 Voltage Low
P0204   Injector Valve 4 Open Circuit
P0220   Throttle Position Sensor (TPS) Circuit 2 Voltage High
P0220   Throttle Position Sensor (TPS) Circuit 2 Voltage Low
P0220   Throttle Position Sensor (TPS) Circuit Incorrect Signal
P0230   Fuel Pump Relay Voltage High
P0230   Fuel Pump Relay Open Circuit
P0325   Knock Sensor 1 Circuit no Signal
P0335   Crankshaft Sensor Open Circuit
P0335   Crankshaft Sensor Incorrect Signal
P0340   Camshaft Position Sensor Circuit No Signal
P0340   Camshaft Sensor Incorrect Signal
P0351   Ignition Coil 1 High Input
P0351   Ignition Coil 1 Incorrect Signal
P0352   Ignition Coil 2 High Input
P0352   Ignition Coil 2 Incorrect Signal
P0353   Ignition Coil 3 High Input
P0353   Ignition Coil 3 Incorrect Signal
P0354   Ignition Coil 4 High Input
P0354   Ignition Coil 4 Incorrect Signal
P0403   Exhaust Gas Recirculation (EGR) Valve Voltage High
P0403   Exhaust Gas Recirculation (EGR) Valve Voltage Low
P0403   Exhaust Gas Recirculation (EGR) Valve Open Circuit
P0443   Fuel Tank Ventilation Valve Voltage High
P0443   Fuel Tank Ventilation Valve Voltage Low
P0443   Fuel Tank Ventilation Open Circuit
P0500   Vehicle Speed Sensor Circuit Incorrect Signal
P0560   System Voltage High Input
P0560   System Voltage Low Input
P0565   Cruise Control SET and RESUME active
P0566   Cruise Control Off Signal Circuit no or Incorrect Signal
P0567   Cruise Control Resume Signal High Input
P0568   Cruise Control Set Signal Circuit High Input
P0571   Brake Switch Circuit Low Input
P0602   Security Code Not Programmed
P0602   Vehicle Identification Number Not Programmed
P0602   Variant-Coding Not Programmed
P0602   Electronic Control Unit (ECU) Not Programmed
P0700   MIL request from Transmission Control (TC) Modul
P0700   EOBD Error stored by Transmission Control (TC) Modul
P0704   Clutch Switch Input Circuit High Input
P1120   Accelerator Pedal Position Sensor 1 High Input
P1120   Accelerator Pedal Position Sensor 1 Low Input
P1120   Accelerator Pedal Position Sensor 1 Incorrect Signal
P1122   Accelerator Pedal Position Sensor 2 High Input
P1122   Accelerator Pedal Position Sensor 2 Low Input
P1230   Main Relay Circuit Voltage High
P1230   Main Relay Open Circuit
P1326   Knock Control Maximum Spark Limit Cylinder 1
P1327   Knock Control Maximum Spark Limit Cylinder 2
P1328   Knock Control Maximum Spark Limit Cylinder 3
P1329   Knock Control Maximum Spark Limit Cylinder 4
P1405   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High
P1405   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low
P1405   Feedbacksensor Exhaust Gas Recirculation
P1500   Position Controller Position Error
P1500   Position Controller Incorrect Signal
P1520   Powerstage Currentless
P1525   Limp Home Position Error
P1526   Limp Home Adaption Error
P1526   Lower Limit Adaption Error
P1526   Throttle Position Adaption Error
P1526   Throttle Position no Adaption
P1530   A/C Relay Voltage High
P1530   A/C Cutoff Relay Voltage Low
P1550   Electronic Throttle Control Reduced Power
P1550   Electronic Throttle Control Forced Idle
P1550   Electronic Throttle Control Engine Stop
P1551   Engine Torque Always Higher Than Expected
P1555   Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load
P1600   Reprogram or Replace Electronic Control Unit (ECU)
P1606   Replace Electronic Control Unit (ECU)
P1610   Security Code Not Programmed
P1650   Service Light Voltage High
P1650   Service Light Voltage Low
U2100   CAN-BUS Malfunction
U2101   CAN-BUS Maximum Configuration List not Programmed
U2104   CAN-BUS reset counter overrun
U2106   CAN-BUS no Communication with TCM
« Last Edit: 12 December 2007, 09:36:10 by Mark »
