Author Topic: Simtec 56 2.0l Fault Codes  (Read 13331 times)
« on: 26 March 2008, 22:19:02 »
DTC       Diagnostic Trouble Code Storage Condition
P0100       Mass Air Flow Sensor Voltage High
P0100       Mass Air Flow Sensor Voltage Low
P0110       Intake Air Temperature Voltage High
P0110       Intake Air Temperature Voltage Low
P0115       Coolant Temperature Voltage High
P0115       Coolant Temperature Voltage Low
P0120       Throttle Position Sensor (TPS) Voltage High
P0120       Throttle Position Sensor (TPS) Voltage Low
P0130       02 Sensor Circuit Voltage Higr
P0130       02 Sensor Circuit Voltage Low
P0130       02 Sensor Range/Performance
P0135       02 Sensor Heating Voltage High
P0135       02 Sensor Heating Voltage Low
P0170       02 Sensor Rich Exhaust
P0170       O2SensorLeanExhaist
P0201       Injector Valve 1 Volte High
P0201       InjectorVal
P0202       Injector Val
P0202       Injector Valve 2 Voltage Low
P0203       Injector Valve 3 Voltage High
P0203       Injector Valve 3 Voltage Low
P0204       Injector Valve 4 Voltage High
P0230       Fuel Pump Relay Voltage High
P0230       Fuel Pump Relay Voltage Low
P0325       Knock Signal Voltage High
P0325       Knock Signal No Signal
P0335       Incorrect RPM Signal
P0340       Camshaft Sensor Incorrect Signal
P0351       Electronic Spark Timing (EST) Line Coil Cylinder 1+4 Voltage High
P0351       Electronic Spark Timing (EST) Line Coil Cylinder 1+4 Voltage Low
P0352       Electronic Spark Timing (EST) Line Coil Cylinder 2+3 Voltage High
P0352       Electronic Spark Timing (EST) Line Coil Cylinder 2+3 Voltage Low
P0403       Exhaust Gas Recirculation (EGR) Valve Voltage High
P0403       Exhaust Gas Recirculation (EGR) Valve Voltage Low
P0410       Secondary Air Pump Relay Voltage High
P0410       Secondary Air Pump Relay Voltage Low
P0443       Fuel Tank Ventilation Valve Voltage High
P0443       Fuel Tank Ventilation Valve Voltage Low
P0500       No Vehicle Speed Signal
P0505       Idle Air Control Voltage High
P0505       Idle Air Control Voltage Low
P0560       Battery Voltage High
P0560       Battery Voltage Low
P1229       Power Supply Relay Primary Circuit Voltage High
P1230       Power Supply Relay Secondary Circuit Voltage Low
P1326       Knock Control Maximum Spark Limit Cylinder 1
P1327       Knock Control Maximum Spark Limit Cylinder 2
P1328       Knock Control Maximum Spark Limit Cylinder 3
P1329       Knock Control Maximum Spark Limit Cylinder 4
P1501       Immobiliser No or Wrong Coding
P1502       Immobiliser No Signal
P1503       Immobiliser Wrong Signal
P1530       A/C Relay Voltage High
P1530       A/C Relay Voltage Low
P1600       Reprogram or Replace Electronic Control Unit (ECU)
P1601       ECU Box Temperature High
P1690       Telltale (Check Light) Voltage High
P1690       Telltale (Check Light) Voltage Low
P1740       Torque Control Voltage Low
P1740       Continiuous Torque Control
« Last Edit: 26 March 2008, 22:21:36 by TheBoy »
