Author Topic: Inside the powersounder  (Read 16645 times)
« on: 18 April 2009, 19:01:40 »
Powersounder showing part no.
Sounder opened, side view.
Sounder exposed view showing battery placements.
Sounder batteries.
I used a hacksaw on the join of the body needing to cut through about 4mm. Just need to source a battery supplier or alternative batteries.
This sounder is from the facelift model so not sure if a different battery set-up was used on the earlier models.
« Last Edit: 19 April 2009, 20:38:47 by Mark »
Welung666
Inside powersounder part 2
« Reply #1 on: 19 April 2009, 10:01:01 »
I have ordered a QJ35Q 7.2V / 1800mAh from Maplins, it's actually a rechargable pack from a remote control car. They have the standard Tamiya connectors (not sure if male or female though) once they arrive I'll get either of these to suit. I plan on extending a wire from the sounder and mounting the battery pack further back. This will also make replacement in the future a ot easier :y
please merge with the other thread if deemed suitable
pics to add to power sounder battery "guide"?
« Reply #2 on: 02 June 2009, 22:36:37 »
inside power sounder of my 3.2 facelift. Shows different soldered in batterys.
Some minor signs of battery leakage highlighted by screwdriver. No damage to circuit board from battery acid.
« Last Edit: 02 June 2009, 22:42:51 by chrisgixer »
