Author Topic: How to Remove Clocks Panel  (Read 26207 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« on: 16 October 2007, 23:23:01 »
By lowering the steering coloumn you show a pozi-driver screw, remove it.
Close the centre vents, then with a Butter Knife carefully prize out the Centre Blower Vents.
Once Centre Vents are removed there will be two more pozi-driver screws in the corners, this will allow the Centre Vent Housing to be removed.
With the Centre Vent Housing removed you will see a pozi-drive screw to the end of the MID.
« Last Edit: 01 August 2008, 16:10:36 by TheBoy »
Re: How to Remove Clocks Panel
« Reply #1 on: 01 August 2008, 16:09:54 »
(OLD FLASH VERSION)
I video of the procedure can be seen at http://images.omegaowners.com/images/guides/How_to_Remove_Clocks_Panel/dashremove.html
(NEW MP4 VERSION)
Clocks Removal Video
« Last Edit: 27 June 2019, 08:39:29 by Jimbob »
« Reply #2 on: 14 November 2009, 09:18:28 »
DO NOT SWITCH ON IGNITION WITH INSTRUMENT PANEL REMOVED. If you do, you will need the airbag light reset.
