Author Topic: Changing automatic transmission fluid (ATF) (AR35)  (Read 20448 times)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« on: 14 November 2010, 18:00:26 »
Hello, after making sure my Elite is maintained to the highest of standards using some of the guides on here, I thought I'd make this little 'how-to' to help others.
I set about changing my ATF as I strongly suspected it hadn't ever been changed, and was right! Benefits from doing this job could include longer gear box life, possible increased m.p.g., quieter and smoother box. Mine is the AR35 box, I don't know how similar the AR25 box is, but hopefully this can be used for that box aswell.
Tools required:
Chocks, axle stands, socket set, hammer, oil tray (old washing up bowl), rags/newspaper/old carpet, jack, torque wrench. Optional - barrier cream, knife, wood chisel, sand/emery paper. I also bought a B&Q easy watering 5 litre pressure sprayer (in a nice fetching green shade), to get the new fluid in. It was ideal for the job, cost £16, and can be cleaned out and used in the garden. (B&Q code 0000003643402)
Parts required:
N209 27 01 filter, 4L30E, AR25, Vauxhall 44mm £21.01
N209 25 02 rear pan gasket, GM 4L30E, Vauxhall £5.10
N209 25 01 front pan gasket, GM 4L30E, Vauxhall £3.76
You will need to double check part numbers and prices yourself through JPAT as I lifted this info from another post. I got my parts from Dave Kember at A.B.S. for £40 delivered, which was quick and easy.
Dexron 3 ATF. From dry I believe the box holds 8.8 litres. This method got about 5.5 litres out. I purchased 9.1 litres (2 x 4.55) £39 delivered.
The job:
1.   Take car for a short drive to warm the ATF so it comes out more readily.
2.   Park on flat, level, firm ground. Handbrake on, jack and stand drivers side, chock the wheels. Use non slip interface between stands and car (such as old carpet patch, wood etc), so there is no metal on metal and less chance of slipping and you becoming a pancake. When jacking the car, I find it best to select 'neutral', because when the car is jacked I find it rolls onto the 'park' peg, then when you select another position it gives a big thud when the peg is released which doesn't sound healthy. Only do this though if your handbrake is upto the job.
3.   There is the potential to make alot of mess, and ATF isn't DKNY, so use old carpet/newspaper/rags to protect ground, and gloves/barrier cream to protect you so you don't stink! Haha!
4.   Position oil tray/old washing up bowl under level plug. This is situated half way up the drivers side of the rear (biggest) sump. You'll know it when you see it, it's not a drain plug hence not at the lowest point. Slacken level plug (13mm IIRC), don't fully remove, let ATF flow out into your container (not a great deal at this point). Be very careful as you are working near the cat. converters which will be quite hot even after your short drive. Hand tight level plug - to avoid spillage when sump comes off.
5.   Undo (16 x 10mm IIRC) bolts with washers from large sump and place to one side. After removing the bolts my sump still wouldn't come off. Here is the awkward bit! Carefully support sump whilst 'encouraging' it to come off with a hammer, and avoiding spilling ATF everywhere! I used a few loosely fitted bolts to help support it. Don't hit it too hard you don't want to damage it! Drain ATF into container. Repeat for small sump. There is an ATF cooler pipe bracket next to one of the sumps that one of the bolts go through. Once all the bolts are out just move it round so the sump comes off easily.
6.   Once my sumps were off I noticed half the gaskets were baked to the sump and the rest were still on the car! I used a Stanley knife blade, wood chisel, rag and sandpaper to get it off the car, it was a little awkward. When doing this be very careful as the blade comes very near to the wires and internal workings of box, which you do not want to damage! Nor do you want to get bits of gasket/particles inside!
7.   Remove remaining baked on gaskets from sump pans away from car (and preferably in a warm garage!) Clean out sumps and degrease (not vitally important - but I only got 5.5 litres of ATF out on this job so every little helps! Check for metal bits in the bottom.
8.   At this point you could consider removing/flushing cooler pipes to get more ATF out - I, however, didn't.
9.   Remove the filter (A.K.A. fluid screen) which will present itself after you take the large sump off (3 bolts). With container under here still, and engine off, move the gear gear selector through the range to encourage more ATF out. I have heard you can clean and re use/save the filter. I'll be doing that to mine later! Wipe off old ATF from underside and clean up mating faces.
Addition by TheBoy: Clean the magnet which sits in the large sump.  The amount of metal stuck to this gives a reasonable indication as to the state of the box.
« Last Edit: 15 November 2010, 16:29:43 by TheBoy »
TC and BnQ Trade holder.
geoffr70
  • Sunderland
  • Boobies
Re: Changing automatic transmission fluid (ATF) (AR35)
« Reply #1 on: 14 November 2010, 18:12:53 »
You are now in a position to re-assemble.
10.   Fit new filter (20nm)
11.   Refit both sumps (making sure the mating faces are clean) with your nice new gaskets. Bolt sumps to gearbox (12nm). Don't forget ATF cooler pipe bracket. I have heard you can use sealant (don't know what kind) instead of gaskets, I of course used gaskets.
12.   Get your shiny new B&Q pressure sprayer (in green) or the like and fill with ATF. Don't use the lance/gun. I found it easier to use just the hose. Undo level plug, don't lose washer like I nearly did! Insert hose into sump and pump your new ATF inside. You might get about 4-5 litres in before it starts to come out the level plug.
13.   Tighten level plug. Get car off stands. Go for short drive, engaging all ranges including reverse. This should circulate ATF and fill small sump aswell.
14.   Get car on stands again, pump more ATF into sump as the level will have gone down when the small sump was filled. Put container back under sump, lower car to ground and with engine running any excess fluid will drain into container. Tighten level plug to 33nm, wipe sump and Bob's your uncle!
15.   It might be a good idea to re-check the level again after 20 miles or so using the guide in the maintenance section. http://www.omegaowners.com/forum/index.php?topic=90508.0
Note
This is just meant to be a helpful guide, not a comprehensive set of instructions. Sorry for stating obvious, but be careful when working under car, check and re check stability. As said I only got 5.5 litres out from a total of 8.8 litres, so I might do it again in a month or so!
Bye! :P
P.S.
Pictures to follow.
« Last Edit: 27 September 2011, 10:36:24 by Jimbob »
geoffr70
  • Sunderland
  • Boobies
« Reply #2 on: 15 November 2010, 20:00:51 »
This is the level plug. It is on the drivers side towards the rear of the sump.
Hear are the two sumps, large at back and small at front. You can see the level plug in the top left corner.
This is the old filter. No pic of it on car due to being messy. You can see the 3 bolt holes clearly. You will see this when you get the big sump off.
ATF, and my pressure sprayer from B&Q.
« Last Edit: 29 November 2010, 14:12:28 by jimbob »
