Author Topic: Removing wishbone bush  (Read 12572 times)
razzo
  • Crapital
    • 97 3.0 Elite
« on: 01 April 2011, 16:58:03 »
If you don't have access to a press or blowtorch here is an alternative way of removing the bush, with the wishbone removed
pop out the plastic inserts with a screwdriver
then we need to cut or drill out the centre piece of the bush, i cut this one as deep as possible then drilled the rest of the way through
once it has come out
you then need to cut the outer edge of the bush to enable removal
when this is done it can be levered out with a screwdriver
and removed
you should then be left with the outer shell which needs to be cut through with a hacksaw from the inside
don't cut too deep otherwise you will cut into the wishbone rendering it dangerous, remember you can always cut out a bit more, but if you cut out too much you can't add a bit more in. Usually you can get away with one cut & bash it out with a chisel or drift, mine were solid so two shallow cuts were needed and the outer shell was levered in with a screwdriver
after a bit of encouragement with a drift and hammer it should pop out and you will be left with this lot
you can now replace the bush with polyurethane as recommended on here as they just press in easily enough get the geometry set up and save a bit of money on tyre wear
hope this helps and best of luck
Steve  :y
« Last Edit: 13 April 2011, 09:21:38 by jimbob »
