Author Topic: help needed  (Read 4569 times)
shelby66
  • bn25 3na
    • omega 2.5 v6
help needed
« on: 09 October 2011, 23:59:07 »
Hi i'm new to site, have urgent question. well 2 actually
i have an omega T plate 2.5 V6, it has to minor/major problems.
1. have a very load grinding noise on front nearside wheel but only when turning right, i have taken off the wheel, checked tire, inner wheel, inside wheel arch even the brake plate and nothing, any ideas or suggestions.
2. have a very bad water leak, having to top up rad every day, not leaking from the rad itself but leaking above the gear box, have checked  and think i can see where its coming from but not sure, again any ideas tx
Re: help needed
« Reply #1 on: 10 October 2011, 00:43:49 »
Welcome to OOF   :y
You'll get more help if you post your questions in the Omega General Help section  ;)
But in answer to point 2) - It'll probably be your HBV (Heater Bypass Valve) situated behind the engine to the left of centre - it'll drip ontp gearbox.  PITA to swap - there's a howto on here.
HTH
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: help needed
« Reply #2 on: 10 October 2011, 00:49:40 »
welcome to the forum shelby. :y
grinding noise could be the backing plate rubbing on the disc. water leak, as said..hbv.
put your location in, somebody near maybe able to help.
Re: help needed
« Reply #3 on: 10 October 2011, 15:34:24 »
How do you do Shelby, welcome along. :y
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: help needed
« Reply #4 on: 10 October 2011, 16:00:56 »
welcome :y
Omega_Dan
Re: help needed
« Reply #5 on: 10 October 2011, 18:37:25 »
Hello and Welcome :y
Re: help needed
« Reply #6 on: 10 October 2011, 19:20:39 »
"Hello" and Welcome :)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: help needed
« Reply #7 on: 10 October 2011, 21:33:25 »
hi & welcome :y
Re: help needed
« Reply #8 on: 10 October 2011, 22:22:17 »
Hi & welcome  :y
Jusme
  • North Hykeham, Lincoln.
    • Lexus LS430
Re: help needed
« Reply #9 on: 10 October 2011, 22:31:36 »
Hi, Welcome to the OOF..  :y
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
Re: help needed
« Reply #10 on: 11 October 2011, 08:37:06 »
Hi and welcome ;)
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: help needed
« Reply #11 on: 11 October 2011, 11:44:12 »
Hiya welcome :y
MV6Danny
  • Swindon, Wiltshire
  • Driving at the speed of light
    • 99 irmscher mv6 3l Manual
Re: help needed
« Reply #12 on: 13 October 2011, 10:27:32 »
Hi and welcome to OOF  :y
Back in the MV6 again now
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: help needed
« Reply #13 on: 13 October 2011, 23:44:18 »
Hello,Welcome to the Forum :y
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: help needed
« Reply #14 on: 15 October 2011, 13:20:27 »
Hello And Welcome To OOF Matey!  :y
