Author Topic: 2013 Nav Query  (Read 18134 times)
2013 Nav Query
« on: 19 October 2011, 19:19:24 »
With a CID does the nav disc have to be inserted and read before the GPS indicator turns green :-\
Big_Al
Re: 2013 Nav Query
« Reply #1 on: 19 October 2011, 19:36:12 »
just taken my disc out Rob.
Then switched ignition on  & selected NAV.   but you cannot select any destination etc. until disc is loaded.
Hope this is what you meant :-\ :-\ :-\
Re: 2013 Nav Query
« Reply #2 on: 19 October 2011, 19:38:57 »
RobG - No :) - it will get the details without the disk.
No green (or yellow), no (delboy voice) statalites.
Re: 2013 Nav Query
« Reply #3 on: 19 October 2011, 19:39:14 »
So your screen is still working ok Al ? :y :D ;D (10 days)
Big_Al
Re: 2013 Nav Query
« Reply #4 on: 19 October 2011, 19:39:46 »
bloody hell whens that edit function gonna be available.
right start again . .
Removed disc ..  switched on ignition  .. selected NAV     . .    GPS is showing green    ..   but you cannot select a destination etc.
Put disc in . . same as above but destination selectable
Big_Al
Re: 2013 Nav Query
« Reply #5 on: 19 October 2011, 19:42:01 »
yep !   guess you'd better Patent that repair system Albs . .  ;D ;D ;D ;D ;D
Re: 2013 Nav Query
« Reply #6 on: 19 October 2011, 19:42:07 »
This one is struggling to aquire the satellites but if left on it will eventually aquire them and indicator will turn green. Any ideas??????????
Re: 2013 Nav Query
« Reply #7 on: 19 October 2011, 19:43:06 »
Poor signal.
(aerial or connection).
Re: 2013 Nav Query
« Reply #8 on: 19 October 2011, 19:45:50 »
Poor signal.
Check everything from rear of HU back to aerial I presume ???
Re: 2013 Nav Query
« Reply #9 on: 19 October 2011, 19:48:25 »
Poor signal.
Sadly, yup.
If its been disconnected from batt for a while, it could be slow to initially grab the signal, but once acquired, should be fine next time.
Its own diags mode will tell you visible and sats in use. Code reader can also tell this.
Re: 2013 Nav Query
« Reply #10 on: 19 October 2011, 19:53:20 »
Ah the magic dance of buttons to get it in to diag mode.. which I had to do about 15 times every time I wanted to select it because I could never remember the right magic dance  ;D
Re: 2013 Nav Query
« Reply #11 on: 19 October 2011, 19:54:55 »
Poor signal.
Sadly, yup.
Pray tell ???
Re: 2013 Nav Query
« Reply #12 on: 19 October 2011, 20:03:45 »
Should give details of it in the handbook. :y  Dont tell me youve flogged all your handbooks ?  ::) ;D
Re: 2013 Nav Query
« Reply #13 on: 19 October 2011, 20:04:48 »
Plan a route. Then press and hold MAIN for 7 seconds. Then press either MAIN or NAV again (may have to experience) - I'm after Nav Test Screen 1
First 2 numbers, top left - 00/00  (first is sats used, second is sats available)
From: http://www.omegaowners.com/forum/index.php?topic=89420.0
Re: 2013 Nav Query
« Reply #14 on: 19 October 2011, 20:17:28 »
Scenario; the disc I`ve got is scratched to hell. Insert it and walk away for 20 minutes, satnav functions appear, but the GPS indicator will only turn green when I have said functions on screen. Eject disc, gps turns red. Insert disc, another wait of about 20 mins, functions appear. :-\
Pages: [1] 2 3 4  All   Go Up
