Author Topic: Siemens NCDR1500 not turning ON  (Read 10500 times)
ksareen
« on: 03 January 2012, 11:23:29 »
Hi all,
Happy new year!
Apologies for posting an Astra query in Omega forum, but the audio system in my car is found far more in Omega than any other Vauxhall, so I am hoping to get some help here..
I've a 2001 Astra with Siemens NCDR1500 stereo which had been working fine till recently..
I've recently come back from a holiday, the car was parked for 10 days and battery was flat when I opened the car.
So the car was jump started but the NCDR1500 has not turned ON since.
I've also previously jump started the car a few times but my radio never asked for a code and always worked fine!
I thought maybe the power button is playing so I tried the EJECT CD option (which usually turns it ON) but no joy, there is an audio CD inside.
Also checked the associated fuses in the fuse box (Fuse 19-10A, 34-20A & 21-5A). They all seem fine.
Any ideas what else to check?
Thanks in advance..
« Last Edit: 03 January 2012, 11:25:14 by ksareen »
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Siemens NCDR1500 not turning ON
« Reply #1 on: 03 January 2012, 11:26:44 »
is there a fuse on the rear of these headunits ?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 03 January 2012, 11:39:46 »
Yep, and only ever pops when jump started !!
Radio & Decoding Technician
www.dndservices.co.uk
ksareen
« Reply #3 on: 03 January 2012, 12:38:09 »
Thanks fiend61 and Dave DND. I will take the unit out tonight and report back.
Could you please let me know if its a normal astra fuse (mini fuse) or any special one (size, rating etc)?
Thanks..
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 03 January 2012, 12:45:55 »
Standard 10A (sometimes 15A) blade fuse from memory
« Reply #5 on: 03 January 2012, 12:47:44 »
10A, normal blade style
« Reply #6 on: 03 January 2012, 12:51:35 »
Location of fuse...
(Model shown is NCDR1100, but its identical to NCDR1500 in every way except the front bezel)
« Reply #7 on: 03 January 2012, 12:52:58 »
Whats probably troubling for any normal sane person, why did I happen to have a NCDR1100 within arms reach that I could photograph!
    • 530D M Sport, 330i Coupe
« Reply #8 on: 03 January 2012, 13:31:29 »
That makes me in-sane then....!  :y
Welung666
« Reply #9 on: 03 January 2012, 13:32:37 »
It had crossed my mind  ;D  ;D   ;D
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #10 on: 03 January 2012, 17:50:55 »
oh , nope, can;t say as it was troublign me at all,  WE all thought it was obvious mate......  the answer is simple .....
because you're "TheBoy"
it's just assmued you will have all sorts of useless crap lying around.....   :y
« Reply #11 on: 03 January 2012, 18:00:16 »
I need to get rid of a load of it, make some space in the garage  :-[
