Author Topic: Seat bits before I forget  (Read 44007 times)
« on: 22 January 2012, 16:49:23 »
Here...
http://theboy.omegaowners.com/oofpics/Seat_odds
Stat - 7k cold, 3.5k heated with hairdryer for 30s
Dash switch, 8k (pos 1) to 0.5k (pos 5)  (I need to reconfirm these), OC on pos 0
Seat out, back off, possible to narrow down to back or base.
Seat out, base cushion half off to expose heating controller, possible to diagnose if heaters, stat or controller (assuming switch values and power proved present at seat plugs before removal.
Airbags involved, batt off, so radio code/windows sunroof etc.  Occupancy sensor known to be delicate.
All for facelift leather, clips on cdx cloth appear to be rings on base rather than push fit clips.
controller outboard centre, stat inboard rear
Re: Seat bits before I forget
« Reply #1 on: 22 January 2012, 16:49:58 »
stat pic removed to follow.
« Reply #2 on: 22 January 2012, 17:45:52 »
Glad that guide makes sense to you :-X :-X ::) ::) :D :D
Good idea to get the info on here though as your memory is rubbish ::)
