Author Topic: kyb springs  (Read 1135 times)
pauls
  • By the sea minehead
    • Bmw x3
kyb springs
« on: 19 February 2012, 17:31:07 »
Evening can somebody tell me if i fit kyb springs all round can i getaway with the same shocks or do i need to change them aswell and if so which ones.On a budget so cant go down the mv6 swap over route that i wanted to. :'(
Re: kyb springs
« Reply #1 on: 19 February 2012, 18:06:59 »
Kyb don't make lowering springs for omega. So standard shocks will match. But only you can tell if your shocks are in good enough nic. Check the stroke of the front shocks when you remove your springs, make sure there's no dead or stiff spots in the compression(in) and rebound(out) stroke, and that there's no oil leaks.
 Does make economic sense to change the shocks if at all possible though. But needs must. :y
