Tonight I was driving along a dual carriageway, speedo probably somewhere up by 80. I overtook a car, using sport mode, and then pulled back into lane 1. As I pulled in, I took S mode off.
A few seconds after doing this, the light with the car and the spanner came on. As soon as I pulled away from next roundabout, it was obviously in limp mode, pulling away in top gear. (MUCH slower on the uptake than just the snow button, foot to the floor it makes loads of noise and hardly goes anywhere).
I could change through the gears manually. but when going from 1 to 2 etc there was a delay, and a thud.
I turned off the engine, restarted - light still on, same symptoms.
I then stopped the engine again, removed key, re inserted and restarted. Fault no longer there, and appeared to be starting out in first gear again.
I checked for codes -
no codes in the gearbox or engine ECU stored (yes I carry a code reader in the glovebox, it's an Omega!!)
Then, upon pulling away from a standing start, admittedly quite quickly - this all happened so fast I can't explain it properly, but, at about 5,000 rpm, there were a series of THUDS as if the drive was being interrupted... it shook the whole car REALLY badly on each thud (my passenger said it hurt her). I may have imagined this, but as it happened, it felt like the back end swang around quite a lot. (I had exactly the same a few weeks ago, and put it down to a diesel patch, obviously not)
I also feel like the autobox has a bit of a vibration/rumble, when slowing down and coming to a stop...
What could have caused those thuds, and awful violent shaking of the whole car? TC, something inside the box?
Guessing in abscence of codes, check for the pesky thrust washer first?
Anyone got a spare AR35? Or even better, an R28 manual box, do the job properly for once and for all?
