Pages: 1 2 3 [All]   Go Down
Author Topic: Intermittent spanner light.  (Read 30757 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« on: 17 September 2024, 12:08:25 »
I'm getting the spanner warning light coming on now and again, code reader says 1 DTC found, but never a code. I've tried it a few times but nothing, and car the is running perfectly. I know this is one of those 'how long is a piece of string?'' questions, but I've got a 500mile rounder to do next week and don't want to push my luck with a possible developing fault......if there is one?? :-\
Re: Intermittent spanner light.
« Reply #1 on: 17 September 2024, 13:34:12 »
Try the pedal trick, as probable the generic code reader is a piece of junk.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #2 on: 17 September 2024, 13:51:39 »
Can you do the pedal trick on a 3.2? did it on the 3.0 which worked OK.
« Reply #3 on: 17 September 2024, 13:56:46 »
I assure you you didn't do a pedal trick on an Omega 3.0.
Pedal trick works on 2.6/3.2 :y
GastronomicKleptomaniac
  • Online Online
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #4 on: 17 September 2024, 14:04:56 »
Tbf there's nothing saying you can't use a bike pedal rather than a paperclip on a cable throttle car...
Pedal trick works on my 3.2 :y
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #5 on: 18 September 2024, 07:52:07 »
Actually it wasn't the 3.0,it was an early 2.0 that wasn't OBD compatible, I stand corrected. :)
    • 530D M Sport, Elite 3.2
« Reply #6 on: 18 September 2024, 08:31:18 »
Pedal trick works on 2.2, 2.6 and 3.2, everything else is a paperclip to flash the codes out.
« Reply #7 on: 18 September 2024, 09:41:34 »
Not sure about 2.2, dont think it does on either petrol or diesel.  Nor does it work on BMW engined Omegas.
2.2 petrol, 2.6 and 3.2 are broadly OBDII compliant, though the 2.2 is really fussy. Technically, they are all only EOBD compliant.
« Reply #8 on: 18 September 2024, 21:26:38 »
My 03 Desmond did allow the pedal trick, a couple of other.cars that I worked on ;)
« Reply #9 on: 19 September 2024, 08:02:39 »
99% certain it didn't work on Tunnie's 2.2 or AA's 2.2, hence they needed tech2.  Tunnie's was definately on the latest firmware available for his engine ECU....
Maybe there are some odd variants about :)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #10 on: 19 September 2024, 12:51:54 »
Pedal trick shows PO571, Cruise control/brake switch ''A'' malfunction, hence having no brake lights upon checking. So now the question...is this a standard brake  switch, or being linked to the cruise control is it different to a non cruise switch?
« Reply #11 on: 19 September 2024, 14:59:45 »
The guide for retrofitting cruise control should clarify :y
A quick look suggests the brake light switch is universal, but manual cars require the clutch switch to be fitted as well.
So to answer your question simply replacing the brake light switch should solve the issue.
As an aside, if you press the brake pedal with the ignition on/engine off, can you hear a click by the selector lever and does it change out of park without issue?
« Last Edit: 19 September 2024, 15:05:17 by Doctor Gollum »
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #12 on: 19 September 2024, 16:12:30 »
Unfortunately....no click from the selector, whether that will change with a new brake light switch fitted. Also there's a hint of an electrical gremlin in the hazard lights which will need  attention from my rubber hammer. ::)
    • Grandland 1.6 diesel
« Reply #13 on: 19 September 2024, 16:15:46 »
You mean fortunately, it means it's definitely the brake switch.
Diesel till I die
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #14 on: 19 September 2024, 16:18:57 »
good point from dg above . does it actually come out of park ? . we assume so cos you have never said car was undriveable or is the solenoid system somehow not in use ???
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #15 on: 19 September 2024, 17:21:52 »
Car is/was driveable, until I did the pedal test, sort of blessing in disguise, as I was going to take it up North....and thinking 200+ miles up the M6 and back again without brake lights oooer! :o
« Reply #16 on: 19 September 2024, 19:02:51 »
Is it an ex plod? If so they may have bypassed the shift solenoid and wired it into a since removed runlock.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #17 on: 19 September 2024, 22:23:38 »
No, this the high miler blue Elite, generally been a good car but just having a couple of probs at the moment. Will get the brake switch ordered for next week and get it booked in....torn rotator cuff says I won't be doing it though! ::)
Rangie
  • Lincolnshire
    • RRS TDV8 Yaris Cross
« Reply #18 on: 20 September 2024, 07:13:32 »
Rotator cuff injury ugh ! Did mine about 4 years ago when we were in Cornwall lifting a water barrel so painful ,resorted to private physio in the end which helped immensely still get the odd twinge if I overdo it, all part of getting old I suppose .
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #19 on: 20 September 2024, 16:20:44 »
Yeah, I've got arthritis in the same shoulder and neck.....it's a treat for anyone to witness me trying to get out from under a car....beached whale is a term commonly used, but getting under is aided by gravity which isn't so bad. Thinking of letting the three Omegas go, as I'm 76 next month and it's getting hard work, and I'm very drawn to the Kia Stinger to go Tesla hunting in ;)
Rangie
  • Lincolnshire
« Reply #20 on: 20 September 2024, 17:18:14 »
Know the feeling very well , I changed the oil & filter in the Subaru about 18 months ago, when I eventually managed to get out from under it I swore that was the last time I'd get under any car. The Stinger seems a lot of car for a very reasonable price..👍
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite. Boxster. C1.
« Reply #21 on: 20 September 2024, 18:11:21 »
Im heading the same way, although Im not 65 until next month.
My head is still full of ideas about doing things to my cars but its getting harder to actually get out there and do them.
I made a determined effort to get under the Boxster to do a half hour job yesterday. It took over an hour and a half, and I felt like I had been hit by a train when I climbed back out.
Arthritis ( legs and back) and approaching old age are no fun.  :(
Women are like an AR35. lovely things, but nobody really understands how they work.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #22 on: 20 September 2024, 21:11:18 »
Got under the back of the Vectra to have a squint at my repaired exhaust back box, seems ok ish. Wasn't too bad on the way down, but at 79, it's a farkin long way back up.  ;D
« Reply #23 on: 20 September 2024, 21:47:14 »
I feel quite youthful at 62 after listening to all you old buggers!  ;D ;D
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #24 on: 21 September 2024, 07:53:46 »
Thanks for those comments, seems there's quite a few of us, but  feeling the need to get under a car when it comes back from an MOT, with the dreaded advancing corrosion advisory seems to trigger the need to get in there go nosing around....maybe I can get one of those nursing home style hoists, and get SWMBO to lower me up and down as and when ::) :y
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #25 on: 21 September 2024, 11:47:37 »
I would love to have a workshop with a two or four post lift. Im sure that would prolong my spannering by a few years at least.
Its never going to be a possibility though unfortunately.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #26 on: 22 September 2024, 08:42:54 »
Sounds good.....under floor heating and A/C,  big screen TV, recliner, coffee and tea making, mini bar...not sure if there's anything missing  OK,  a minion or two to work on the cars, and then it's just another day in Paradise :)
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #27 on: 22 September 2024, 11:06:27 »
Yep, that sounds like paradise to me. When I win the lottery................... ::) ;D
countrywoman
  • worcestershire
    • skoda yeti
« Reply #28 on: 23 September 2024, 10:30:31 »
Join the queue !! If I do it will be a small bungalow with a large workshop!!
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #29 on: 23 September 2024, 16:39:58 »
Or a big house  with a small garage.
Convert the garage into a house and the house into a garage.  ;D
« Reply #30 on: 23 September 2024, 17:15:47 »
 ;D ;D ;D ;D ;D ;D sounds like a plan to me!  :y :y :y
Pages: 1 2 3 [All]   Go Up
