Pages: 1 2 [All]   Go Down
Author Topic: Project A Brake Bleed....  (Read 3272 times)
    • Zafira Tourer & BMW 435i
« on: 11 August 2006, 00:06:50 »
Firstly I would like to thank TheBoy & Mrs TheBoy for showing me how to do a full brake bleed yesterday.
I would also like to thank TheBoy for letting me borrow his brake bleed kit (bit of clear pipe and a pot)
Glad to report a did a full bleed on my Project A and replaced the fluid... and it now brakes much better. - Very satisfiying feeling since it had no braking at all to begin with! :o
Quite chuffed now I have done it, first real major thing I have done on my car.
Some pictures of the days events:
Jacked up back passenger side in the garage....
With the pipe attached to the brake bleed i got mother to pump the brake, on shouting the command 'push' she pushed and held the pedal, i then realsed the nut slightly and let the old brake fluid flush out. As soon as it began to slow in presure i closed the nut. Then gave the command 'Release to mother' - This continued several times to drain the system, then once it was topped up it was done again to get the new liquid though.
When i first started i put a little bit of brake fluid in the pot, just incase it tryed to suck back. Instead of air it would get brake fluid.
The tube going to the pot....
Yummy, old brake fluid.
Managed to flush a lot of air out of the system, well chuffed  :)
Kev
  • Glasgow
  • .:The OmegaProject:.
Re: Project A Brake Bleed....
« Reply #1 on: 11 August 2006, 00:12:57 »
Well done.  [smiley=thumbsup.gif]
Had to do my own when i upgraded to drilled and grooved discs with GreenStuff pads.
The difference is, well, noticeable.  ;)
And it does make you feel good when you can do it yourself.
« Last Edit: 11 August 2006, 00:14:09 by Kev »
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
« Reply #2 on: 11 August 2006, 00:14:38 »
Really noticed it! - Plan to do the same on my facelift along with new pads.
Kev
  • Glasgow
« Reply #3 on: 11 August 2006, 00:16:00 »
There's no stopping you now!!
Well, there is, but you know what i mean.  ;D
« Reply #4 on: 11 August 2006, 00:19:19 »
 ;D ;D
I can now easily do a change of pads, brake fluid, oil & filter change.
Basics, but its a start  :D
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 11 August 2006, 02:03:24 »
I hope to achieve that 'basic' status myself very soon too. Well done pal!    [smiley=thumbsup.gif]
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #6 on: 11 August 2006, 02:04:20 »
Oh, forgot to say thanks for the pics. Every little helps!!   [smiley=happy.gif]
« Reply #7 on: 11 August 2006, 07:35:18 »
The next thing to buy then is a proper 9mm(?) combination spanner rather than your very expensive looking move-able spanner. You'll end up with rounded off nipples ... ooer!
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #8 on: 11 August 2006, 08:23:21 »
Well done Tunnie
Basic maybe, but all vital jobs and to be able to this sort of thing yourself is a real money saver - plus you know it is done right!
If, as Andy B recommends, you start purchasing tools, be warned that this is quite addictive, not to mention expensive.  I do not allow myself to look at tools anymore! ;D
Be sure to keep us updated with your progress.
1998 2.5 V6 Omega CDX, Leather and Electric Pack!
« Reply #9 on: 11 August 2006, 08:36:44 »
Well done Tunnie :), and good to put the piccies up.  Some may consider it basic, but there are people, such as yourself, who may never have done it before, so the piccies really help  [smiley=thumbsup.gif]
When you do your pads on the 2.2, may be worth buying new pad sensors if the previous owner/garage had just shorted wires together.
BTW, I still reckon when we did my nsf on the MV6, my fluid was dirtier than yours - thanks Crownhill Vauxhall/Evans Halshaw/whatever you're called this week - that was not 18 month old fluid  >:(. Thieving scumbags  >:(
nixoro
  • Hitchin, Herts
« Reply #10 on: 11 August 2006, 09:08:10 »
Well done tunnie  :)
This is one of the jobs I still need to do on my car, cheers for posting up the pics should come in handy for those that haven't done it before.
« Reply #11 on: 11 August 2006, 10:18:16 »
Thanks for the comments all, unfornutley my camera died while doing the bleed. When i do my facelift I will prob get some better pictures of the bleed nipples and where they are on the front and rear calipers.
Yep i need decent tools, Jamie would second that as my socket set is not metric  ::)
I found the bleed nipples were not done up too tight so my expensive looking wrench (which was £1 ;D) did the job.
Think i need to get a TC card at this rate! - I need some more GM brake fluid so i will get some sensors as well.
TheOutcast
« Reply #12 on: 11 August 2006, 10:28:35 »
They’re not alone. I had mine changed at W. Grose in Northampton. I'm sure that they just changed the fluid in the reservoir. There’s certainly no obvious sign that they touched the bleed nipples.
« Reply #13 on: 11 August 2006, 10:29:32 »
If you need brake fluid in a hurry, I have a couple of 500ml bottle here, and I'm about until 4ish.  I don't have any sensors though (which is a bugger, as i busted one the other day :()
« Reply #14 on: 11 August 2006, 10:58:35 »
did you manage to bodge the old sensor back on?
I have the pads here so i might as well, just don't have the sensors. But I can put those on at a later date.
I need to work on the facelift today anyway as the scuttle is still blocking the drivers side washer jet.
Might pop around in a bit and get the fluid, quite interested to see how much Pad is left on the fronts on my facelift.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #15 on: 11 August 2006, 10:59:19 »
nothing more satsifying than doing the job yourself....you know it's been done properly then.
I use an eazy bleed kit, easy to use and no pumping of the pedal....
As for the dealers changing fluid, hmmmm how can i put this...
I used to work in a Vaux dealers, on more than one occasion i saw a mechanic drawing the old fluid out of the reservoir with an old petrol pump and then topping it up with clean stuff!!!!
Kev
  • Glasgow
« Reply #16 on: 11 August 2006, 12:03:36 »
And that's just the kind of thing that has brought us all together.  ;)
« Reply #17 on: 11 August 2006, 12:24:57 »
I said this to Tunnie when we saw the state of mine...   ...scumbags...
« Reply #18 on: 11 August 2006, 13:45:09 »
Idealy you should squeeze the calipers in when changing the fluid whilst the bleed nipples are open to get the real gunky stuff out...
« Reply #19 on: 11 August 2006, 14:16:52 »
Did that one side on mine, but broke the pad sensor :(
I will get the shite out of the other when I changing the discs/pads....
« Reply #20 on: 11 August 2006, 14:46:28 »
Its the stuff in the calipers that causes the real problems......
« Reply #21 on: 11 August 2006, 14:49:03 »
yup, agreed (esp as it looked like those scumbags at Crownhill Vx emptied reservoir and refilled, rather than proper bleed  >:() - but I didn't want to break pad sensor until it needs renewing (few weeks).  When I change the discs (pattern, keep warping) and pads I shall rebleed that one caliper...
Kev
  • Glasgow
« Reply #22 on: 12 August 2006, 21:41:52 »
A bit off topic, but why can we say shite, but we can't say smoking a fag?  :o
« Last Edit: 12 August 2006, 21:42:18 by Kev »
« Reply #23 on: 13 August 2006, 12:47:28 »
better as the admins that one, guess its not in the filter... 'damn' was being filtered before, the F word is filtered so is f.c.u.k i think??
Liam
  • Da Ghetto, Kempston Rural, UK
« Reply #24 on: 13 August 2006, 13:26:36 »
Hmmm thanks for that - has inspired me to do my own.  Always thought my pedal has excess travel (although MarkDTM says they're meant to be like that).
I have a simple kit that is basically just a tube like you used but with a one way valve on the end.  Means you can just pump the pedal without worrying about nipple tweaking cos you can't suck anything back up.  Good for the first flush of old fluid, but I still do the last few pumps 'properly' i.e. with the spanner and a second person, as even with this one way valve kit you can, i believe, suck air in via the thread of the slackened nipple.
Liam
P.S.  Blame Americans for f_g being on the filter.  They really dont like that one.
« Reply #25 on: 13 August 2006, 13:38:38 »
lol must be carefull not use that next time i am over there...
Glad you found it of use, i shall be doing a bleed on my facelift megga soon, which will have better pics
Pages: 1 2 [All]   Go Up
Page created in 0.045 seconds with 21 queries.
