Pages: 1 2 [All]   Go Down
Author Topic: Coolant transfer pipe o-ring  (Read 3269 times)
Stu.C
  • Lancashire
    • 2.0 Capri / 2.6 Elite
    • Visit the blog...
« on: 29 June 2022, 09:45:37 »
I've searched based on what I think it's called, but most results seem to refer to a pipe by the thermostat. The thing I'm talking about is the big one that runs from the rad to the back of the block.
Does it have an o-ring at the block end? And if so, does anyone have a part number or size for it please? There's a slight coolant leak at the joint, and before I undo it, it'd be a good idea to have a replacement to hand, if there's one needed.  :y
Nothing better to do ? Visit the blog at cuyahoga.co.uk
Enceladus
  • London
Re: Coolant transfer pipe o-ring
« Reply #1 on: 29 June 2022, 12:40:10 »
Looks like it's GM# 9128362. And not cheap. I would imagine that any good seal supplier should have something suitable. Can you get the old seal off and measure it? If the engine is out of the car as in your photo should be a lot easier.
« Last Edit: 29 June 2022, 12:45:22 by Enceladus »
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #2 on: 29 June 2022, 16:24:49 »
Indeed, that's the problem with me using an old pic to clearly show where I'm talking about. The engine is fully dressed at the moment and full of coolant.  :-\
At least I now know its 37mm, but not yet whether that's ID or OD, and thus what thickness it is. Searching the Saab parts suppliers off the back of that part number wasn't really turning anything up either. Ah well, if nobody else pipes up beforehand, I'll just have to solve the mystery when I get to it - luckily I'm in no real rush...  :y
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #3 on: 29 June 2022, 21:27:10 »
 Re-use old one, and put some silicone on the mating face's.
Hoof'land storeman.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #4 on: 29 June 2022, 21:51:48 »
You can't suggest that! It will downgrade several GM Original Parts Supply VirginsTM and where would we be then?
Worse than that, it ought to work
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #5 on: 29 June 2022, 23:38:12 »
Lucky I checked, I was just gonna go to Screwfix ...  ;D ;D ;D
Enceladus
  • London
« Reply #6 on: 30 June 2022, 03:24:43 »
Isn't that dielectric grease for waterproofing towing hitch electrical connectors and similar?
The seal in question is between the engine block and transfer pipe. Wouldn't it be better to smear some grey high temp RTV onto the old seal instead?
« Reply #7 on: 30 June 2022, 08:50:56 »
RTV won't do anything for the o ring.
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #8 on: 30 June 2022, 10:40:39 »
It was there for comedic effect - obviously on a different wavelength.
Like I said, I'll see what gives when I take it apart. A smear of Hylomar Blue has usually been sufficient over the years with the cooling on the Capri.
biggriffin
« Reply #9 on: 01 July 2022, 11:44:55 »
  Well he could use GM black goo, that wouldn't invalidate the warranty...
Hoof'land storeman.
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #10 on: 04 July 2022, 23:02:11 »
Well that was messier than I'd planned. I didn't count on there still being so much coolant left up high after draining the rad  :-\
Right, well to answer my own question the seal is 37mm ID, 41mm OD and is currently about 1.2mm thick. However the groove it sits in is about 1.2 and a smidge millimetres deep  ::)
Over the last twenty four years and however many miles, it's baked itself a little dry and shrunk. It may have originally been an o-ring and got absolutely squashed, or it may have been flat to start with. I'll have to browse the Yellow Pages and talk to some seal folks to see if they've anything suitable. Meantime I'll maybe try soaking it in coolant to get a bit of life back in it, then pop it in with a smear of Hylomar and see if that does the trick - it's easy enough to trial, in the grand scheme of things ...
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #11 on: 04 July 2022, 23:18:39 »
how about a metre of 1.4mm o-ring cord for £2.21? LINK
Join the ends with a spot of super glue and you're done. This probably isn't a solution for a high pressure/temperature system, but a car's cooling system is neither of those
LC0112G
« Reply #12 on: 04 July 2022, 23:18:51 »
If the groove in the aluminium pipe is 37mm ID and 41mm OD, then the O ring is probably supposed to be 2mm section. Summut like this:
https://www.ebay.co.uk/itm/191760537489
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #13 on: 04 July 2022, 23:43:44 »
Well there's something I never knew existed  :y
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #14 on: 05 July 2022, 09:06:56 »
You're probably right, and a quick check of O-ring specs would prove which size is actually required :y
Raeturbo
  • Online Online
  • South Wales
    • Mv6 3.2 Mitsi Evo2. XJ8
« Reply #15 on: 05 July 2022, 13:12:35 »
I’ve 38x42 O rings  are you sure they are not that size?
Laying a rubber road.
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #16 on: 05 July 2022, 17:29:27 »
It honestly wouldn't surprise me if there were different size pipe, flanges or seals used somewhere along the way, but (based on the crude tools available) a 38x42 wouldn't theoretically fit in the recess of the pipe I've got. Maybe - like a few things - with a bit of lube it'd slide right in, not sure  :o
Rather than pontificate about what it could be, or take a guess, wait for the post, find it's wrong, take another guess, wait for the post again, then resort to Nick's magic o-ring rope - I'm instead going to pop down the road some time this week to Simply Bearings, pipe in hand, and have their experts scope it out. If push comes to shove, I'll walk away with a best guess and a fallback - with a high degree of probability that one or t'other will just work when I come to refit it at the weekend.  :y
« Reply #17 on: 06 July 2022, 23:48:11 »
it's a lot easier to read a digital verynear .... especially when you're an old fart  ;D
biggriffin
« Reply #18 on: 07 July 2022, 08:37:18 »
What size are the plenum O rings??
Hoof'land storeman.
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #19 on: 18 July 2022, 00:46:24 »
Just to follow up on this, I stopped in at Simply Bearings the other day, and if anyone finds this delightful story in years to come - I can tell you they're definitely 2x37mm o-rings you need for the transfer pipe  :y  If you're after one, you're welcome for the price of a stamp, as a bag of ten was little more than the price for two.
Refitted the pipe this weekend, refilled the coolant and no more leak...  :D
We tried 1.5mm section out of interest, but it barely came above the level of the flange once settled in the groove, and wouldn't have made much of a seal.
Pages: 1 2 [All]   Go Up
Page created in 0.027 seconds with 18 queries.
