Pages: 1 2 3 4 5 [All]   Go Down
Author Topic: Major Service Woe or Two  (Read 3801 times)
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« on: 12 January 2022, 17:14:50 »
Carried out my yearly service today, but the major one that I do every four years based on the mileage I do.
Must be getting older as everything I did was more difficult.   Usual trouble in getting to spark plug 6, but after much cursing the idiots who designed so much in the way of this plug that I have wasted hours on over the years, I finally extracted it.  But, worse to come, was when I found two of the rubber boots on the DIS Pack, on that side of the engine, had split, then the spring contact on one of them became detached from the unit, and fell off somewhere at the front of the engine; lost for now, even after much searching with a torch!!
Anyway, made temporary repairs to the two boots, then fashioned a new spring from copper wire I have in stock.  Put it all back together, fired up the engine and all works!
But, as I know my repairs are temp., contacted my Vx dealer for a new DIS Pack;  Part no 9118115 - Bosch 0221503027 Not available!!!  Even if they were, ONE would be £300+  !!!! :o :o :o
Anyway, after ringing around, looked up the part on Amazon and have now ordered via them the Bosch one from the Green Spark Plug Co. for £97-19 with Prime delivery.  I could have obtained a Starline DIS Pack from ECP for £76-55, but I much prefer an original Bosch.
So now after re-fitting the plenum and everything else, I can now look forward to stripping it all down again!! ::) ::) ::)
I also know I have a slight exhaust pipe leak which I am getting fully underneath the car tomorrow to check out.  This must be done as my MOT is due early February, so more bloody expense!
Owning a 18.5 year old Omega is never going to be easy, nor cheap, but hey ho, the one great thing I discovered today was there NO OIL in the spark plug holes.  Last time the breathers were fully cleaned it was by Serek when he replaced the cam cover gaskets, and cam belt to boot.  He must have done the great job I believed he had done! 8) 8) 8)  Needless to say I have fully cleaned ouit the breathers today.
I just wish Serek and SOS were closer, although he should be doing the cam belt this year. ;)
« Last Edit: 12 January 2022, 17:17:44 by Lizzie Zoom »
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
Re: Major Service Woe or Two
« Reply #1 on: 12 January 2022, 17:22:56 »
You don't need a new pack; the boots off another, failed one would do. Somebody here is bound to have some.
Lizzie Zoom
  • South
« Reply #2 on: 12 January 2022, 17:30:57 »
Thanks Nick, but the missing spring is the problem and although with great expertise ( ;D ;D)  I have fashioned a replacement, I know it is only a temp. repair.  The DIS Pack may go anytime I believe, given its age, so I have jumped in with both feet to get a good replacement whilst I can!
Once again though Nick, thanks for your advise which as always is most welcome! :-* :y :y
« Reply #3 on: 12 January 2022, 17:31:07 »
Also if its the coil pack over the 2/4/6 bank, no need to remove plenum.  I used to be able to do mine in about 15mins, and that included removing the LPG injectors, though my plastic cable tray was on the shelf in the garage, so that saved a few minutes ;D
« Reply #4 on: 12 January 2022, 17:32:47 »
The coil packs probably need replacing occasionally on these anyway.  If the old one is still servicable (not swelling or clear rust visible where the plastic gets hairline cracks, keep as a spare, and acquire some replacement boots.
Lizzie Zoom
  • South
« Reply #5 on: 12 January 2022, 17:34:31 »
That's interesting and useful TB.   :y :y
If I can do that it will certainly save me time (and much cursing!).  My plastic cable tray is still in place, so perhaps I should try and remove it?
I seem to remember on a past 3.0 I did do that :D
Lizzie Zoom
  • South
« Reply #6 on: 12 January 2022, 17:36:29 »
Good thinking!  Along with Nick's great advice, I will do that :y :y
Any spare boots out there anyone?? ;D ;D
« Reply #7 on: 12 January 2022, 17:41:09 »
I have a knackered 135 coil pack somewhere. It's cracked and rusty but the rubbers are fine. :y
Lizzie Zoom
  • South
« Reply #8 on: 12 January 2022, 17:44:48 »
That's very kind of you Opti! :-* :-*
I take it the 135 coil pack is the same as my DIS Pack on my 3.2?  If so send me a PM and I will pay you to send just the three boots for spares.  Many thanks.  8) 8) :y
« Reply #9 on: 12 January 2022, 17:55:36 »
Your Omega doesnt have a DIS, it has coil packs
Lizzie Zoom
  • South
« Reply #10 on: 12 January 2022, 17:59:34 »
Really?  The part I am buying (with pictures that are the same as mine) is described as a "DIS Pack".  I remember replacing the unit behind the engine that distributed the sparks on a long gone 3.0, and I thought that was a coil pack.
Well, as I always say, we never stop learning; everyday a school day! ;D ;D :y
« Reply #11 on: 12 January 2022, 18:14:22 »
My understanding is a DIS is the term usually used for a wasted spark, and coil/coilpack for non wasted spark?
Lizzie Zoom
  • South
« Reply #12 on: 12 January 2022, 18:24:27 »
Now, not for the first time TB, I am lost in that technical assessment!  I have not got a bloody clue now! ::) ::) ;D ;D ;D ;D
« Reply #13 on: 12 January 2022, 18:29:24 »
Coil over plug would be an accurate assessment.
Plugs on the 2.6/3.2 are a twenty minute job every time.
Also, you're looking in the wrong place for GM parts. But you already know that.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Lizzie Zoom
  • South
« Reply #15 on: 12 January 2022, 18:31:29 »
Yes I do, but I now look everywhere for the right brand, the correct part, and at the right price. :D :D :y
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #16 on: 12 January 2022, 18:42:08 »
DIS is Distributorless Ignition System, so it could be either.
johnnydog
  • Lancashire
    • 2.6 & 3.2 sal, 3.2 est
« Reply #17 on: 12 January 2022, 20:15:33 »
Over the years, I have found the biggest killer of the coil packs fitted to the 2.6 / 3.2 is water ingress into the plug wells which accelerates internal corrosion, which can be seen on the metal core at each coil upper end (thick end of the rubber insulator boots), and rusty cracks. Oil in the plug wells will cause the insulator boots to perish at the plug end.
But taking these two causes out of the equation, coil packs should last for an infinite number of years. I have only had to change them on other cars as a result of another issues causing the problem,  ie water leaks from the scuttle or oil from the cam covers.
I have a 2.6 that is still on its original coil packs, and it is now approaching 19 years old and 70k.
Probably jinxed it now.... ::)
2002 3.2 Elite saloon, 2003 3.2 Elite estate, 2003 2.6 Elite saloon
  • Solihull
    • 530D M Sport, Elite 3.2
« Reply #18 on: 12 January 2022, 20:27:48 »
I couldn't change them in that time, it would take me most of that to unpick and remove the tray to be honest. No 6 can be a fiddle but once you remember the combination of bits you used last time it's not too bad.  :D
Lizzie Zoom
  • South
« Reply #19 on: 12 January 2022, 20:43:52 »
I agree with those comments. As I said, Number 6 was again difficult even when trying with various combinations of sockets, extension bars and universal joints.  For some reason it would not loosen up, but eventually it gave up! ;)
I must say that on the Omega V6’s I have always found that plug the most difficult, with a fear I am going to cross thread the new one when I put it in.  I’ve always succeeded in the task though :D :D
Lizzie Zoom
  • South
« Reply #20 on: 12 January 2022, 20:45:11 »
For when I fit the new DIS pack, is the connector on the old one easy to unclip please? ??? ???
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #21 on: 12 January 2022, 20:46:48 »
I usually spent the first fifteen minutes faffing about undoing the cable tray and then pulling the cables clear with a bungee.  ::) :)
YZ250
« Reply #22 on: 12 January 2022, 20:49:08 »
It's just a tab. Flat blade screwdriver under the tab and wiggle it clear.  :y
  • Solihull
« Reply #23 on: 12 January 2022, 21:02:17 »
...then wonder where it's gone when you go to plug in the new coil pack....  ;D
« Reply #24 on: 13 January 2022, 05:17:28 »
No wonder the plug change takes so long if you don't unplug it for that.
10" combination of wobble extensions makes short work of plug 6. The only reason it can be a pig is if it has never been changed by previous laziness.
« Reply #25 on: 13 January 2022, 07:32:48 »
To answer the question re the coil pack plug...
DO NOT bolt it in before you have fitted the plug. This is because the plug naturally falls to a position underneath the coil pack socket and you WILL crush it if you bolt the pack down on top of it.  :y
« Reply #26 on: 13 January 2022, 07:51:07 »
Bosch coil packs are still available, there is a good seller on ebay (Powersparks) who I have used quite a bit without issues.
They have them listed for about £77 delivered:
https://www.ebay.co.uk/itm/154596665618?fits=Model%3AOmega&epid=249114263&hash=item23feade912:g:ObQAAOSwmz5hM0O2
and
https://www.ebay.co.uk/itm/185032225768?fits=Model%3AOmega&epid=248933317&hash=item2b14c7b3e8:g:d3wAAOSwZD5hM0O3
« Reply #27 on: 13 January 2022, 07:53:35 »
As for DIS and Coil pack, the DIS was a module which utilised wasted spark tech to replace a distributor but, still had traditional HT leads.
Then came the 'coil per plug' or 'coil on plug' as it was sometimes called, directly connecting the coil to the plug with no external wires, some manufacturers combined mulitiple coil on plugs into a single 'coil pack'.
« Reply #28 on: 13 January 2022, 08:56:06 »
 Usual trouble in getting to spark plug 6, but after much cursing the idiots who designed so much in the way of this plug that I have wasted hours on over the years, I finally extracted it.  .....
Plugs on an Omega & even No 6 plug on a Senator are dead easy compared to my Smart Roadster.  ;) ;)
Rear panels off first
Then all 6 plugs .... top 3 are easy .... lower 3 not so easy
« Reply #29 on: 13 January 2022, 09:57:56 »
And some use a single coil to drive two plugs per cylinder with two leads. Because they could.
« Reply #30 on: 13 January 2022, 10:47:23 »
That's what the Smart Roadster uses
« Reply #31 on: 13 January 2022, 11:07:12 »
Thats simply an extension of the wasted spark DIS system, with a lead connected to each end of the secondary winding, but with more turns to get the volts up and a bit more iron to store some extra energy (which may not be good for reliability)  :y
« Reply #32 on: 13 January 2022, 11:08:13 »
The Smart one is two coils in one pack  :y
« Reply #33 on: 13 January 2022, 14:38:08 »
 :y OK ... there's just one block with 2 HT leads from it  ;D ;D
« Reply #34 on: 13 January 2022, 15:06:14 »
If you look closely you can see the two bulges from each coil
If you fed two plugs off a single coil only one plug would fire most of the time  :y
LC0112G
« Reply #35 on: 13 January 2022, 15:41:42 »
That's not strictly true. As long as there is a circuit from one terminal of the coil back to the other terminal, it'll fire. The second terminal doesn't have to be a chassis/ground potential.
I can name at least one case where the circuit goes coil+ve -> spark plug1 tip - >spark plug1 threads -> cylinder head ->spark plug2 threads -> spark plug2 tip -> coil-ve.
Both spark plugs 1&2 fire every time at the same time. One cylinder is at the top of the exhaust stroke, whilst the other is at the top of the compression stroke. Although the exhaust stroke spark is wasted (hence the term wasted spark), it takes very little energy to fire it when it's surrounded by hot combustion gasses, so the energy loss is minimal.
It makes spark timing simpler - you can do the timing off the crank (rather than the cam) since you don't need to know if the piston is in the compression or exhaust phase of the 4 strokes.
No idea if that's how a Smart car works though.
Lizzie Zoom
  • South
« Reply #36 on: 13 January 2022, 16:24:18 »
Thanks! :y :y
Lizzie Zoom
  • South
« Reply #37 on: 13 January 2022, 16:29:18 »
Yes, that does seem far worse than with the Omega, and much, much harder than a Senator which was dead easy! ;D ;)
Lizzie Zoom
  • South
« Reply #38 on: 13 January 2022, 16:37:31 »
No, I never have, but there again I have only done two major services on the current Omega.
As for changing plug 6;  I always have, but I now realise my mistake of not removing the cable tray on the current car.  I did on the 3.0's I have had, but usually when replacing the cam cover gaskets.  When I did those, I used to change my plugs as part of the major service.  Why I have reverted to not doing that I cannot explain, but perhaps I am tiring of all this car mechanics malarkey at my growing age! ::) ;D ;D ;D ;)
« Reply #39 on: 13 January 2022, 17:25:52 »
As soon as you said it knew you were right ....  ;) but checked on one of my spare coils  ;D
« Last Edit: 13 January 2022, 17:28:47 by Andy B »
« Reply #40 on: 13 January 2022, 22:02:08 »
What you describe is how a wasted spark coil works. One plug of the pair is always in a cylinder on its exhaust stroke, so it has no compression, and needs a much lower voltage to break down than the one that has full compression pressure on it, hence both plugs fire but most of the energy from the coil goes to the one under compression since it has a much higher voltage across it by the time it fires.
If you connected two in the same cylinder, in parallel, to a coil on a twin spark setup like the Smart, you'd only ever get the "easiest" plug firing since the current would take the path of least resistance, hence you need a pair of coils.
    • Astra 1.6 diesel
« Reply #41 on: 13 January 2022, 22:11:49 »
My first wife only had a single coil in, and she certainly used to fire on all cylinders. Dirty cow, she was.  ;D
She wore out my piston  :(
Diesel till I die
    • 2 Fords
« Reply #42 on: 13 January 2022, 23:36:53 »
Does that mean you also have a wasted spark Uncle STEMO?  ???  :-\  ;D
Raeturbo
  • South Wales
    • Mv6 3.2 Mitsi Evo2. XJ8
« Reply #43 on: 13 January 2022, 23:56:16 »
So you’re pissed and broke then my friend?🤣
Laying a rubber road.
Raeturbo
  • South Wales
« Reply #44 on: 13 January 2022, 23:57:12 »
May be a gummed up ring😂😂🤣
« Reply #45 on: 14 January 2022, 07:31:27 »
You missed this by a country mile   ;D
This is two plugs on the same cylinder, not a wasted spark setup. In this case if you had a single coil the plug with the smallest gap or most optimum conditions will fire, once it has the ionised air/mix in the gap will reduce in resistance and the spark remains on the one plug.....hence two plugs per cylinder nees two coils (well at least two secondary coils)
LC0112G
« Reply #46 on: 14 January 2022, 09:31:41 »
Yes - if the two plugs are in a parallel combination. However, nothing to stop you wiring them in series, even if both plugs are in the same cylinder.
I'm struggling to see the reason for firing two plugs separately in parallel in the same cylinder, unless the timing is such that they are firing them at slightly different times?
« Reply #47 on: 14 January 2022, 09:50:27 »
It's a Mercedes thing  ;)
The M112/113 engine uses coils as Mark pictured, which have two short leads running to individual plugs. In turn there are two spark plugs per cylinder.
Incidentally, they're all 3 valve engines so there's a plug for every inlet valve. Presumably making combustion more efficient...
So my S280 V6 has 6 coil 'packs' (paired coils), 12 leads and 12 plugs. The V8 has 8,16 and 16 respectively, and the V12 M156/275 has 2 coil packs, no leads and 24 plugs :D
« Last Edit: 14 January 2022, 09:52:21 by Doctor Gollum »
« Reply #48 on: 14 January 2022, 13:41:42 »
No it ain't. A fair few manufacturers do in on "normal" cars, and quite a lot on performance cars.
For LG - fired at the same time, idea being a better burn from 2 flame fronts.
« Reply #49 on: 14 January 2022, 14:06:50 »
Thats not actually a single coil, its two secondary windings with the centre grounded and a single primary  :y
LC0112G
« Reply #50 on: 14 January 2022, 14:45:12 »
So remove the centre ground tap, and it then becomes a series spark setup with one primary and one secondary :y
Would be interesting to continuity check from the plug lead terminals to chassis/ground.
Lizzie Zoom
  • South
« Reply #51 on: 14 January 2022, 15:07:40 »
God, my Omega DIS Pack, or whatever it is,is a damn sight easier to understand than all that! :o :o :o :o
I must remember never to buy a Smart car! Is that the car that needs the engine out to replace the exhaust pipe?  One of my friends had one of those and she explained how the Mercedes mechanic complained about having to work on such a design of car! ::) ::) :D :D
How I miss the simplicity of past cars with a coil, distributor, contact, leads to each plug witch had a simple connector that was easily changed!  My A40 was a doddle to work on compared to these modern machines!  Are the electrics going to be easier? ;D ;D
« Reply #52 on: 14 January 2022, 16:57:18 »
OK, my experience of it twin plugs is the Merc application. Fiat/Alfa with their twin spark could well be a similar set up.
Incidentally, the M104 straight six developed from distributor ignition to three double coils each feeding two single plugs per cylinder.
« Reply #53 on: 14 January 2022, 18:33:26 »
I think the coil would have to be enormous to generate 2 sparks on the compression stroke.
LC0112G
« Reply #54 on: 14 January 2022, 19:03:05 »
It's the same primary coil either way and therefore the energy stored in the magnetic field is the same since there is only one primary. The energy discharged per spark event is therefore also the same.
If there are two secondaries then presumably half the energy stored in the core gets discharged through each of the two coils/plugs. Doesn't matter if the centre connection between the two coils is grounded or not. If it is then you end up with +V on one terminal and -V on t'other. If it isn't then you end up with 2*V between the terminals, but it's floating wrt ground. The ground comes then from the fact that the two plugs are screwed into the cylinder head, so the threads will (probably) be grounded - but they don't have to be.
I don't know that thats how it wired on the Smart - it's possible that both coil terminals go to +V wrt ground (rather than +V and -V). But that gives you a DC current in the head as the return path for the spark which isn't a good thing generally.
« Reply #55 on: 14 January 2022, 21:49:47 »
Interestingly, I have discovered that the Audi Totally Frigging Stupid Idea lump has two plugs per cylinder... As does the 2008 ish 5.7 Hemi lump :D
« Reply #56 on: 14 January 2022, 22:50:22 »
I miss points, condensers & dizzys like a hole in the head .... they were a pain in the harris!!
And though I've yet to replace an exhaust on either Smart (different engines), I doubt that's correct. They're not the easiest of cars to work on engine wise
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #57 on: 14 January 2022, 23:07:19 »
Yes, they are the first thing to get rid of on an old car. Especially now that high quality points and condensers are hard to find.
« Reply #58 on: 14 January 2022, 23:22:50 »
And the Continental IO 520... From the late '60s 8)
So no, apparently not just a Mercedes thing  :y
« Reply #59 on: 14 January 2022, 23:49:18 »
Pretty much all aero engines do.. for redundancy.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #60 on: 15 January 2022, 08:05:30 »
Ah yes, but getting the timing just right after fitting new points/dis etc. gave a certain    satisfaction.
« Last Edit: 15 January 2022, 08:07:46 by Shackeng »
countrywoman
  • worcestershire
    • skoda yeti
« Reply #61 on: 15 January 2022, 09:37:48 »
Yes the satisfaction of getting something like an MGB to run sweet , balancing twin SUs !!!
Lizzie Zoom
  • South
« Reply #62 on: 15 January 2022, 13:01:25 »
And though I've yet to replace an exhaust on either Smart (different engines), I doubt that's correct. They’re not the easiest of cars to work on engine wise
I loved doing all the ‘stuff’ on the old cars, and got great satisfaction in setting the timing.  Yes we had to use feeler gauges more, but what simplistic fun that was.  We were in charge then, but now when servicing or repairing my Omega, like all modern cars, I feel the car is in charge with all the bloody sensors we have to obey! :o :o ;D ;D
No fun now, just I have to do it, a slave to my car ;D ;D ;D
Lizzie Zoom
  • South
« Reply #63 on: 15 January 2022, 13:03:38 »
Yes, it certainly did :D :y
But, I was much younger then…….!!! ::) ::) ;)
« Reply #64 on: 15 January 2022, 15:25:17 »
And aftermarket electronic ignition systems have become loads more reliable than those in the 70/80s
« Reply #65 on: 15 January 2022, 15:29:31 »
Its not really that different, only stuff is done in software, and the feedback is in black and white, rather than by gut feel. Which leads to more consistent accuracy.  But essentially, you are still looking at the same things for incorrect running, just on a screen instead.
Lizzie Zoom
  • South
« Reply #66 on: 15 January 2022, 15:50:39 »
Yes TB, I know.  Modern cars are certainly better in so many ways, and not just greatly assisted by all the electronic gizmos, such as big end failures are now almost non-existent, piston ring failures the same, and as for head gasket break-downs..........well, I suppose the list is endless.  The time we used to see the same old brands of cars broken down at the side of the road!!
So, yes once I take off my rose coloured glasses........................................I still miss the simplistic fun of working on the old cars, but not at the side of a lonely road............without a mobile phone to summon help! :P :P ;D ;D ;D ;)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #67 on: 15 January 2022, 16:35:35 »
Does anyone remember Sparkrite system? i fitted one on one of mine , but can't remember which one. :-[
« Reply #68 on: 16 January 2022, 13:24:26 »
I used to set the ignition timing on my RD 250 like this.
Screwdriver down the plug hole to locate TDC.
Homemade light bulb connected  to the points to check when they opened. It worked pretty well most of the time although I did end up with a holed piston once after a long flat out thrash during the peak of summer. :-X
A dial gauge may have been more accurate but I couldn't afford one. :'(
Lizzie Zoom
  • South
« Reply #69 on: 16 January 2022, 13:43:29 »
Yes those days of poverty mechanics, working with the few tools we could afford to keep our old machines going by a wing and a prayer, learning on the job. Still have fond memories of all that ;D ;D
Pages: 1 2 3 4 5 [All]   Go Up
Page created in 0.07 seconds with 18 queries.
