Why is it all of ya are like "yeah.. Go on.. Have a go yourself, I'm a musician not a have a go type"
The vauxhall omega is a nightmare car to work on, just watching Syme yesterday do his thing yesterday was daunting enough, I've only ever done a coolant change!
TBH Wayne, you have had many offers of help in the past and even been told that what you think are problems are not. The recent water pump squeal which turned out to be the Aux Belt Tensioner (which I and others suggested without even seeing it) being a good example of you panicking and jumping in at the deep end
Whilst the OOF spirit is all about helping people we can't always drop everything and do it straight away
The heater issue: Sounds like it may well be an air lock. It's quite possible that your mechanic decided to disconnect coolant hoses during his work
You say you've done a coolant change in the past so I would suggest you bleed the cooling system properly, as you will have done then, and see if it improves. Also, disconnect
and plug the vac line to the HBV temporarily to see if you get heat. It's not complicated and you don't have to undo any screws
That will prove the HBV faulty or not. I wouldn't be at all surprised if a pattern HBV has gone faulty after 2 years
