Omega Help Area => Omega General Help => Topic started by: mantamania on 11 March 2012, 22:23:11
Title: camshaft sensor
Post by: mantamania on 11 March 2012, 22:23:11
Hi all,
I have just done a cylinder head gasket on my 2.2  When it came to start the engine, it would not fire up. The only fault that registered was for the cam-sensor.
Do camshaft sensors just check for rotation of the camshafts or do they check that the timing is ok?
Title: Re: camshaft sensor
Post by: doz on 11 March 2012, 22:28:57
I maybe wrong I'm not overly familiar with the 2.2 but I think the ecu uses the cam sensor to fire the injectors during start up. I know the v6 will run with it unplugged but not start.
Post by: VXL V6 on 11 March 2012, 22:31:26
Will run on just crank sensor but will be a bugger to start and will run in limp mode.
Post by: mantamania on 13 March 2012, 17:55:32
Today i fitted a new cam sensor but the car does not start.  Traced the wiring back to the ECU and found no breaks in the wires.
Post by: doz on 13 March 2012, 17:57:03
Are you still getting a cam sensor error code
Post by: ndmv6 on 13 March 2012, 18:00:16
any more codes?last time i had this,it was the crankshaft sensor...engine ran with a faulty cam sensor,but wouldnt start with a faulty crank sensor...coil pack connected ok?
Post by: ndmv6 on 13 March 2012, 18:02:31
was it a genuine gm cam sensor..?
Post by: TheBoy on 13 March 2012, 18:08:48
Is cambelt timing correct?
Post by: mantamania on 13 March 2012, 18:11:40
Hi all,
I used a genuine GM sensor, and still got p0340 fault code, no other codes listed.
