Omega Help Area => Omega General Help => Topic started by: opelfreek on 12 March 2012, 21:06:38
Hey :)
Wondering if anyone has replace flywheel on a x30xe, one from a different engine (xe / let / xev) to get one that is lighter than the original V6 flywheel (15kg)
If so, what have you taken and what clutch did you spend?
Hey :)
flat type flywheel from early c20xe/let 6.4kgs
clutch plate from vectra B v6
pressure plate c20xe/let
need spacer for slave cyl.
[/quote]
What kind of spacer do i have to use then ?? just to adjust the Slav cyl. to the clutch ?
this what you need :y :y
http://www.migweb.co.uk/forums/items-sale/494361-c20xe-omega-r25-r28-gearbox-clutch-adapter-kit.html
Thanks :y :y
Hey :)
Hey Serek !!
Are you sure that the only clutch plate i could use is from vectra B v6 ?? can`t i use someting else ?
Sincerly
Richard.
I think i'm getting on this one...
Does anybody know the length of the spacer?
I can make it and the dia's are easy, just need the length...
Also, What's the bolt pattern on our x30xe's? Looks like the c20xe has 8 bolt holes....
Got one in mine but was already fitted when I got the car now a bit worried as to when I need a new clutch they will fit the wrong parts
Just found this but I would still make one...
http://www.ebay.co.uk/itm/Vauxhall-C20XE-Red-Top-Omega-B-R25-R28-Geabox-Clutch-Adapter-Spacer-Kit-/270978107997?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f178dca5d#ht_1852wt_1026
I would get the parts listed above and tell them to compare them to the old ones....
Or do the job yourself??? Not that hard....
Does anybody know the diameter of both of these flywheels, X30xe vs c20Xe???
Inner or outer diameter ?
Inner diameter is the same, that i found out yesterday when i try the c20xe flywheel on my X30XE engine/cranksaft ;)
Is it a straight swap then? It was the outer that I was referring to....
I need to do something as my DM is buggered! Clank, clank....
Also, I'm guessing the point of this mod is faster engine response, better engine braking and maybe impoved fuel economy???
Just faster engine response, really. You might find slightly quicker acceleration in the lower gears, but the main reason to do it is to allow the engine revs to fall faster from the red line as you change up the gears, and for quicker response when "blipping" the throttle to match the revs on downshifts.
It won't affect engine braking or economy.
Hey :)
Hey Serek !!
Sincerly
Richard.
hi sorry for late replay,
the vectra
B V6 clutch plate its the cheapest option and easy to find on ebay form like 5£
I have them for sale, half price what this bloke have :)
I was lead to believe that with a lighter mass of the flywheel, you gain engine braking???
Which I think is almost non existent on the Omega, well it is on mine anyway???
Silky smooth free revving equal balance 6 cyl makes it feel like that :)
MPGs may increase but not really noticably, just less turning mass on the engine etc, same as losing the air/con pump (no on)
Diameter would be the same, or the starter wouldnt work :)
[/quote]
Yes it was an straight swap. I don`t know the outer diameter..
Haven`t got the engine and the new flywheel in the car so i don`t know how it is going to work :o
Know you say that :-[ i have just payd for one :o
the vectra
[/quote]
Mkey... i havent found anything on ebay. Mabye i hav to search some more then :)
How did you get on doing this?
just out of intrest why you want fit solid fly wheel??
DMF has had it and this suits my pocket!
