Omega Help Area => Omega Electrical and Audio Help => Topic started by: LFF64 on 18 March 2012, 19:04:45
Could someone tell me what type of bulb/lamp is used in the puddle lights please ? I know its a festoon type but is it a 36mm or42mm one /
42mm
Thank you Rob :y any chance you could answer a bit quicker next time though ;)
Cheeky sod ;D :P
Cheeky sod ;D :P
Wot!?!? :o
No picture! ::) ::) ::) ;) ;)
Actually yes, but most people would I assume, know what the bulb looks like :P :D
(http://www.leadinglamps.co.uk/images/P/264_new-07.jpg)
We do ............. but as they say, a picture paints a thousand words. ;) ;) ;)
They are actually the smaller 36mm ones as I found earlier
How do you get to the bulbs without breaking the fitting is it a door card off job ?
right side of light is clip flat blade just pops out.
Mine have 42mm`s fitted ???
Is that just the white lens part that comes off or should the complete unit pop out of the door ?
I have some LED type bulbs to replace the standard ones and the ones in the pubble lights are the same as I have in the rear number plate lights and also the same as the lights for the rear doors , the light in the loggage area and the one in the glove box are the longer ones
put the flat blade to the cover the black part the cover should not come off it just cliped into the door card. if you do pop the cover off can glue it back on its only heat bonded.
I popped off the first one :( but stil couldnt get the back part out of the door , I have three more to try to get out in one peice :D
