Omega Help Area => Omega General Help => Topic started by: Andys VXR on 20 March 2012, 17:35:15
I done my stat about two months back because of the lack of heat in the car its lovely now. I havnt used car much in that time only for the odd school run anyway it got a good run today well about 40 miles. When i got home i lifted the bonnet dont ask me why and noticed the rad hoses were rock hard. Is this normal
yes alot of pressure in there when engine has been run for a few miles. :y
You say that, but my top rad hose is always soft, even when hot i can compress it easilly...
Rob
Rob
are all others the same?
They should be firm as its a pressurised colling system (and hence why it boils at greater than 100degC).
If the hoses are soft then it hints at a coolant leak somewhere are excess air in the system.
Rob
No, just the top hose. all others are solid
makes sense, not noticed anything untowards though, water is clean and always sits with-in levels, hot or cold. Oil is all good, fresh and no mayo. As I just said, it's only the top hose thats soft.
Rob
when was the termastat last changed?
