Omega Help Area => Omega General Help => Topic started by: rds on 22 March 2012, 23:09:04
Title: Torque settings with polybushes - front wishbones
Post by: rds on 22 March 2012, 23:09:04
Hello all
just about to fit new polybushes to a low mileage omega estate 53 plate after a chance meeting with this forum's Entwood (cheers Nigel!) and a question arises:
please can someone confirm what are the torque settings for the polybush centre nut/bolt and also for the rear wishbone nut which is to be loosened to give some cleaance on fitting.
There is reference on here to "standard settings" but I can't find those!!
Also, is the percieved wisdom still to torque up with the wheels bearing the car's weight and therefore on ramps?
many thanks
RDS
Title: Re: Torque settings with polybushes - front wishbones
Post by: feeutfo on 22 March 2012, 23:13:50
http://www.omegaowners.com/forum/index.php?topic=101105.0
No need to undo the rearward bush. Won't help anyway.
Post by: feeutfo on 22 March 2012, 23:15:28
And to be clearer, polly do not need to be tightened wheels loaded.
Post by: rds on 02 April 2012, 11:11:46
Hi Chris
thanks for the replies and info/link. Sorry i havent thanked before but i didnt receive an email alerting me to the answer!
Re your comment above, sorry to be a pain but are you saying that unlike normal bushes, the poly bushes can be torqued with the car on axle stands rather than ramp?
With poly bishes are you still recommending running back and forth to settle?
also do the polybushes have a shorted life expexctancy?
cheers
RDS
Post by: Zippy2012 on 02 April 2012, 12:05:12
Hi Chris
cheers
RDS
ide of thort they would out last a standard bush because they dont perrish or soften over time.... ???
Post by: Kevin Wood on 02 April 2012, 12:16:57
Poly bushes can be bolted straight up (same torque settings) without any requirement to load the car or settle the suspension. This is because the central tube actually rotates in the bush as the wishbone pivots. With a conventional bush this movement is achieved by the rubber twisting so it was important to ensure that no strain was on the rubber in the "normal" settled position.
Post by: rds on 02 April 2012, 14:05:49
Many thanks both - sounds like the job may be a little more straightforward then....
RDS
Post by: Nick W on 02 April 2012, 18:24:31
Surely the bush rotates around the sleeve that is firmly clamped by the bolt through its centre?
Post by: Kevin Wood on 02 April 2012, 18:58:06
Depends which way you look at it, I suppose. ;)
Post by: feeutfo on 02 April 2012, 20:52:42
By far the worst bit of this job is removing the old bush without cutting into the wishbone.
That done, provided there is room to swing the torque wrench, it's litterally 5mins work to fit the polly bush halves and sleeve, bolt it all up, drop the car off the stands  job done. No wheels loaded, no settling suspension, no messing.
Post by: rds on 18 April 2012, 14:54:00
Hi Chris
yes, i am psyching myself up to do it!! but please forgive me being pedantic:
re the torque settings, i see that the instruction is 120Nm then angle 30 deg then 15 deg.
Ok I get taking it to 120Nm then 30 deg but are you saying a) then  wait  (and tighten a further 15 deg or b) slacken off and retighten to 120Nm plus 15 deg
thanks
RDS
Post by: feeutfo on 18 April 2012, 17:34:29
a) :y
Post by: Andy B on 18 April 2012, 17:39:39
a) :y
You've top trumped The Boy re one word answers ................. you've managed with just a letter!   ;D ;D ;D ;D ;D ;D
Post by: feeutfo on 18 April 2012, 18:40:00
Why write it twice? He's done the work for me, bless him. :y
Post by: rds on 18 April 2012, 22:27:59
not so fast: you didn't say how logn to wait for before continuing the remaining 15deg (that question was implicit in a)!
cheers
RDS
Post by: feeutfo on 18 April 2012, 22:39:52
Nope, not biting. ;D
Post by: rds on 18 April 2012, 22:53:53
well i did try - now to find some time to do it!
RDS
