		Omega Help Area => Omega General Help => Topic started by: Crazycarzowner on 23 March 2012, 22:26:51
				 Changed the camcover gaskets today, it went well really. put everything back together, test drove ok. Then I got the spanner warning. Hooked it up to my test thingy and got this P0330 - (2) Knock sensor 2 circiut Low input (bank 2) present.
 Have I missed pluggin someat back in or have I disturbed someat I shouldn't have?
 TIA
 J
				check to see whether anything unplugged drivers side plenum, also check for trapped wires or loom damage  :y
 TIA
 J
 You`ve trapped and possibly damaged the knock sensor cable (screened co-ax) on passenger side, or dislodged the connector.
 Courtesy of MDTM
 The connector for the knock sensor is indicated by No 2 and the wire clips and runs as shown by No 1
 (http://i23.photobucket.com/albums/b394/Marks_DTM_Calib/Knocksensor.jpg)
				Check passenger side knock sensor is plugged in, and that you haven't caught the wire...
				Whoops!!!  :-[ :-[ :-[ must have not plugged it home firmly enough. Alls well again now, thanks guys  :y
 A nice cheap/easy fix.  :y :y
 I'm surprised that a bloke as big as you didn't manage to push the plugs together first time!  ::) ::) ::) ;D ;D :y
 :P :P :P :P :P :P
 I'm a gentle giant really.  ;D ;D
