		Omega Help Area => Omega General Help => Topic started by: hatman on 01 April 2012, 08:57:58
				CAR STARTED THEN CUT OUT TURNS OVER BUT WILL NOT FIRE UP NO LIGHTS ON THE DASH /CHECKED FUSES AND CONNECTIONS ANY IDEAS  :( :( :(
				turn your caps off its classed as shouting ;)
 have you checked your earth connections :-\
 any codes showing try doing pedal trick as its a 2.6 :y but if no lights on dash maybe difficult ???
				sorry about caps have checked all conections battery is a bit flat been stood for two months but she did start then cut out ,radio and the infomation display come on turn radio off the display goes off as well but no lights on the dash petrol gauge does not move so not sure whats wronge
				think you really need to read codes first have you got access to a code reader :y
 bit more charge in battery maybe  :-\
				do not have code reader going to try charging battery hope this works :y
 Not needed, do the "pedal test" http://www.omegaowners.com/forum/index.php?topic=90581.0
				tryed battery thats ok did the pedal test still nothing think engine management has crashed
 after posting earlier to you i went out to mine and would start then cut out straight away tried several attempts to start it but no joy, try disconnecting the maff sensor and see if it starts and runs,it worked for me and i was'nt getting any codes coming up :y (worth a try imo) :y
				will try thanks but what and where is  maff sencor will check it out in morning will let you know
				look at air filter housing follow the pipe on right hand side as you look at it from the front of car,you will see a short section connected to it with a multi plug connector that is the maff air flow sensor just disconnect the plug from it and see if it starts and runs, it worked for me all i have to do is source a new maff sensor.
 you can drive it with the sensor disconnected but the eml light will come on when you get the display working that is :y may not work but it did for me h.t.h :y
				must say thanks to all who replyed very helpful to a new member  :D :D :D :D
				lets hope it works out for you  :y
				fuel filter blocked up?
				 8)had same problem on my 3.2 turned out to be crankshaft sensor faulty
				had same on mine,faulty crankshaft sensor....it started then cut out 5 times over a period of 6 months,then one day it just packed up all together...
