Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: Agemo on 03 April 2012, 15:46:35
Title: Wanted TD ECU
Post by: Agemo on 03 April 2012, 15:46:35
Can't seem to post in wanted section,m not sure why but could you please move for me?
Wanted, replacement ECU for a 2000 Turbo Diesel. Mine has the letters "JM" so I suppose the new one will have to be the same. Other numbers are:-
2247368 203
078
BOSCH 0 281 001 428
Made in Germany
90 494 180
B 96006
I thank you.
(http://i1181.photobucket.com/albums/x421/Smudge645/test1pc2pvp392-1.jpg)
Title: Re: Wanted TD ECU
Post by: GmasterT on 03 April 2012, 20:18:11
2.5? I think I have one, will dig it out and check the nos :)
Post by: Agemo on 03 April 2012, 20:24:16
Thanks GmT, has to be Diesel 2.5  :y
Post by: TheBoy on 08 April 2012, 12:40:51
More than that - there are 4 different ones fitted to the UK spec TD, and yours is from a X25DT auto. Anything else is incompatible.
Post by: Agemo on 08 April 2012, 17:06:13
Thanks TB, I am still after an ECU, transponder & key chip.  ::)
Post by: unlucky alf on 10 April 2012, 20:49:28
Ive got one somewhere but not sure of the number on it, But the one thing I do know is that it is chipped to +10 :o, i`ll dig it out if there is enough light in the garage & check the number.
Post by: unlucky alf on 10 April 2012, 21:01:50
Ive just dug it out & its a 0 281 001 427 & it came off a manual car by the way. :(
Post by: Agemo on 11 April 2012, 15:30:12
Thanks Alf, but I have one on the way now (touches wood). I will update this post when it arrives. I do appreciate you looking it out though. The numbers on yours are correct apart from the very last digit, which makes it the wrong one. YourS is from a Manual, which  will not fit in an Auto, although apparently it works the other way round. If you are selling the ECU on it's own, it has to go on a Tech 2, and it should be "blanked" first, although early ones may be plug & play, (I am sure someone will confirm this). Thanks again, hope someone can make use of it.
Post by: Agemo on 13 April 2012, 20:15:34
OK, all sorted, thanks to dieseld4. Thread can now be locked.  :y
