Omega Help Area => Omega Electrical and Audio Help => Topic started by: Crazycarzowner on 03 April 2012, 18:57:54
Title: Sunroof electrical gremlins (or a ghost!)
Post by: Crazycarzowner on 03 April 2012, 18:57:54
Got the fright of my life goin to work the other day, just driving along the M62 to do my night shift when all of a sudden WHOOOOSH!!!! I wondered what the hell was goin on, looked around all windows still intact, then looked up, the sunroof was open :o :o :o I hadn't touched it, dial still as was??????????? Its done it again today aswell, I turned on the ignition, started up and within about 2 miles of driving, it opened again!!! (No one told this car it was raining today ;D ;D  ::) ::) )
Anyone any ideas why? or do I have a poltergeist in my car  :'(
Title: Re: Sunroof electrical gremlins (or a ghost!)
Post by: jonny2112 on 03 April 2012, 19:09:08
Ah yes, the old 'phantom sunroof' again. Common issue, which just occurred recently on mine. There is a guide to cleaning the switch in an attempt to cure it. Hasn't worked for me so I'll have to give it another go.
It is a little scary though when it happens  :-X
Post by: RobG on 03 April 2012, 19:18:49
Replacement PCB needed (black box srewed to motor) ;)
Post by: jonny2112 on 03 April 2012, 19:22:46
You think so Rob? Even if it's only an occasional occurrence? Would make sense though  :-\
Post by: RobG on 03 April 2012, 19:23:29
Yep
Post by: jonny2112 on 03 April 2012, 19:26:58
Fair enough pal, thanks. Another part for the wish list ........  ::)
Post by: alank46 on 03 April 2012, 19:31:19
Have you changed or disconnected the battery recently, if so the sunroof needs re-syncing. Push and hold the button in each position of the roof until it clicks.
Post by: Crazycarzowner on 03 April 2012, 20:03:34
Can you still get the replacement PCB Rob??? If so do ya know the part no.????
Post by: RobG on 03 April 2012, 20:47:07
Not sold by GM on it`s own Jason, comes with motor
90459138
Post by: Crazycarzowner on 03 April 2012, 20:58:06
Not cheap then I suppose  :( I might try to clean it first & see if it cures it, if not I'll just pull the plug on it, the air-cons freezing anyway, it just been re-filled, I don't tend to use the s/roof anyway.
Post by: RobG on 03 April 2012, 21:02:37
More trouble than they`re worth
Post by: RobG on 05 April 2012, 19:27:58
Do you want one ::)
Post by: jonny2112 on 05 April 2012, 20:35:55
Do you want one ::)
What took you so long  ;D ;D
PM incoming ..........  :D
Post by: Perplexer on 23 April 2012, 00:37:26
"Phantom roof" problem isn't related to the battery being disconnected and the roof needing to be reset.
See this thread:
http://www.omegaowners.com/forum/index.php?topic=101646.0
